Zinc carnosine - does it affect test results?
Singaporeguy
Hi, is it necessary to stop taking this supplement before a urea breath test? Or any test for that matter.
Only hear about 4 weeks off antibiotics and 2 weeks off PPIs so far..
Also, anyone knows about collagen, probiotics etc?
Singaporeguy
Re: Zinc carnosine - does it affect test results?
Any advice regarding this @helico_expert? Thank you!
anything that may impact on H. pylori number may interfere with the diagnostic tests, eg UBT and Stool test.
Zinc carnosine claimed to have anti-H. pylori effect. Therefore I will see it as an "anti-biotic" and recommend stopping it for at least 2 weeks before the UBT or stool test.
Singaporeguy
Thank you @helico_expert!
Just wondering, why 14 days and not 7 days? There seems to be very little data regarding this..
the cure rate of 14 days is better than 10 days and better than 7 days.
while 14 days treatment has higher cure rate, it also means higher adverse side effect.
Collagen supplements are typically taken to support skin, joint, and bone health. There is no common recommendation to stop collagen supplements before medical tests like the urea breath test. However, if you have any concerns or are taking other medications, it's always a good idea to discuss this with your doctor. Slither io
elliotzucker
Zinc carnosine is a proprietary molecular combination of L-carnosine and zinc. When zinc and carnosine are inserted (chemically bonded), a new nutrient is formed that has specific properties that differ from those of the two elements taken separately. In 1994, this compound was approved in Japan for the treatment of gastrointestinal ulcers. There is no information whether it is an antibiotic. When you have a test, you should ask your doctor first for advice fish eat fish
poetactivist
Almost every test is done to get the most accurate results snene abstain from using fish substances. You should follow up to make sure the results are at the highest percentagegeometry dash. Every study of substances goes through testing before being released to the public.
Some probiotics (like Lactobacillus reuteri and Saccharomyces boulardii) may affect H. pylori colonization but generally aren't strong enough to cause false negatives.
anna99
Zinc carnosine may increase blood zinc levels, which may affect mineral-related tests.
