Allergic to rabeprazole at treatment for Helicobacter
Gramdler
Post by Gramdler »
Good time.
Sorry to interrupt you retire. But I have no choice, I'm not a doctor, but you have to learn the profession, in addition to basic survival.
Helicobacter found in blood (antibodies). Prescribed treatment pantoprazole (40 mg), clarithromynic (500 mg), amoxicillin trihydrate (1g) - 2 times a day, morning and evening. Lactic Axis Bacillus (Bacillus coagulans (Lb.sporogenes) - 120 mio, folic acid (1.5 mg), vitamin B12 (15 mcg) - 2 times a day before meals. And silymarin (Silybium marianum) (35 mg) - 3 times day, after meals.
Under this scheme, I otlechilsya 7 days. Some days I felt better, ranging from 3-4 days. Then a little overworked and physically I felt worse tion appeared in the stomach and nausea, did not exist before. (5 day treatment)
I asked the doctor for advice.
At first I was assigned a drip some substance which was supposed to remove toxins, the body gave a reaction had to use the antidote. (6 day treatment).
On day 7 of treatment was administered intramuscularly Metoclopramide (C14H22ClN3O2) (10 ml). State returned to normal. For the next period of time, the doctor prescribes a diet following medications:
Rabeprazole (20mg) - 1 per day, in the evening.
mosapride (5 mg) - 3 times a day after meals.
Silymarin (Silybium marianum) (35 mg) - 3 times a day after meals.
After the beginning of mosapride - I got sort of swelling, so on day 8 I took it at a dose of 5 mg.
Rabeprazole (20mg) - received the full dose - suffered a pain in his stomach, the feeling was that I was sent into orbit in space.
other drugs - to the full dose.
On Day 9
All was well until, until I took Rabeprazole. After the adoption, I went to bed, falling asleep feeling the pain in the stomach. But did not come to me for a long time to sleep, I woke up in a delirium, gathered nuggets of my mind, I was able to recover, measure blood pressure, which was 144/92 (with the pulse of 89) and took 250 mg metamizol sodium, 20 mg bendazol , 20 mg of papaverine hydrochloride, 20 mg of phenobarbital (one tablet). It seems easier.
Now, on the threshold of 10 per day. And I would like to have aces in this area to clarify some details that I do not understand.
The first thing I do not understand - why would I Rabeprazole? (Because I took a course of pantoprazole, without complications).
In the explicit side-effects, there is an equivalent of Rabeprazole, which provide fewer allergic reactions? (If so required).
I understand that it is not correct to talk of the doctor, but I am worried about my health, I would like to see your recommendations, I continue to be? (And what to take?).
for by a doctor today I thiotriazolin%) (although it may be good, but then after the release of pressure podlechites heart will be very good).
But I think you can restore the flora of the stomach and intestines, without affecting other organs so fiercely that treating one - cripple another.
Thank your for taking the time to read my problem, for any written recommendations, and if necessary will be some more details, ask (I'll try to find the name of the drug that caused the allergy, if it's so important). I hope my story can help other people do not experience the "pleasures of life" being treated by H. pylori, as it has to do to me. Until emergency communications.
Re: Allergic to rabeprazole at treatment for Helicobacter
I think you need to get a breath/stool test to find out if you are still infected with H. pylori.
i dont agree that probiotics should be taken together with antibiotics because they'll simply be killed by antibiotics.
Rabeprazole is a preferable acid reducing agent but any other drug such as pantoprazole will do the job.
i suspect your H. pylori was not killed by your first treatment and so, i would suggest you to stop your rabeprazole for 2 weeks and get a breath/stool test done.
Gramdler
Post by Gramdler »
Thank you for your response. Now I wait two weeks for re-analysis. The reported results.
