helicobacters positive.
mustarirakos
Post by mustarirakos »
The women also complain about a watery discharge and time and again papsmears clean but helicobacters positive.
I cannot tell you how many times I treated women, warning them about pregnancy and those who wanted to get pregnant did get pregnant.
Again time after time the 5 to 6 week miscarriages, positive helicobacter and treat en get pregnant a second time with a succesfull pregnancy to delivery.
The next complaint from my patients is that tiredness that you can only explain as chronic fatigue syndrome or the Yuppy flu.
Some of them are so desperate that they tried succide and said to feel so tired is not worth living.
I thought a lot of the symptoms should be explained by some mechanisms of the chemical reactions in the body by helicobacter but cannot find such researh.
The ammonia in the vaginal fluids was described as killing the sperms because the women are productive normal.
Please give clues., help, etc
*** Edited by Moderator to remove advertising ***
Rex
Re: helicobacters positive.
Post by Rex »
Good information about this disease i tell you something more about it.H. pylori is a major cause of diseases of the upper gastrointestinal tract. Eradication of the infection in individuals will improve symptoms including dyspepsia, gastritis and peptic ulcers, and may prevent gastric cancer. Rising antibiotic resistance increases the need for a prevention strategy for the bacteria.
tamar32
Post by tamar32 »
Hi mustarirakos,
I did not understand what you want to tell us here. Actually I got confused because you have described about diseases and at the same time about pregnancy also. You told that women have also this problem but did not clarified which problem you are talking about. Anyway this is an old post and you must have lost in history now. I will come up with few details on this later.
_________________________
"Going High"
