Second treatment
Firecon
Second treatment
Post by Firecon »
Hello, this is my first post here and I need help...
I got diagnosed on march with H.pylori by a stool test and I have symptoms like constant burping, stomach pain when its empty and constipation.
My first treatment for 14 days was:
Clarythromicin 500 mg twice a day
Amoxicilin 500 mg four times a day
Esomeprazole 40 mg one time a day
Bismuth tablets twice a day
Unfortunately, the treatment didnt work and I am still positive.
When I went again to the doctor he told me that its possible that the first treatment didnt work because my acid stomach leves were still high, so my new treatment for 14 days is:
Bismuth tablets three times a day
He told me that if this doesnt work I would have to change antibiotics.
I also cant do antibiotics resistance test because they dont do it where I live.
My question is: would be worth to try and do it?. I am a bit scared because the antibiotics side effects + it may not work because I am using the same antibiotics.
Thank you for your answers
Re: Second treatment
Since the following treatment failed
you should not try again the second time.
The bacteria is clearly built resistance to this combination.
Since H. pylori almost never become resistant to Amoxicillin and Bismuth, you check with your doctor about swapping Clarthromycin with Metronidazole
maybe also swap Esomeprazole to Rabeprazole (just in case esomeprazole isnt suitable to you)
Helengrace22
Post by Helengrace22 »
Wishing you healing soon! It’s tough, but don’t give up — you’re doing the right thing by staying proactive. Speed Stars
It might be worth asking your doctor about switching to a different antibiotic combo, especially since you’re still symptomatic. Hang in there — it sometimes takes a few rounds, but many people do get better!
gladhyundai
Post by gladhyundai »
Helengrace22 wrote: Tue May 20, 2025 3:55 pm Wishing you healing soon! It’s tough, but don’t give up — you’re doing the right thing by staying proactive.
It might be worth asking your doctor about switching to a different antibiotic combo, especially since you’re still symptomatic. Hang in there — it sometimes takes a few rounds, but many people do get better!Tap Road
Do you have any tips for better health and less stress?
Chinmayi
Post by Chinmayi »
What are the potential risks and benefits of continuing with this second treatment versus seeking alternative options, crossy roadsuch as changing antibiotics or consulting a specialist?
These are the antibiotics that can be reused, as H. pylori hardly becomes resistant to them..
Amoxicillin
Bismuth compound
Tetracycline
Furazolidone
The following antibiotics can only be used once, as H. pylori almost always becomes resistant to them if exposed.
Clarithromycin
Metronidazole
Ciprofloxacin
Rifabutin
marryjoy63
Post by marryjoy63 »
I’d be cautious about repeating the same antibiotics after the first treatment failed. If resistance testing isn’t available, I’d ask your doctor about a different second-line combination and make sure the follow-up test is done at the right time. Hopefully you can avoid another round that doesn’t work. word games online
