Question on HP test
LifeIsShort
Question on HP test
A year back i was declared HP positive via biopsy(endoscopy)..i took the triple therapy and i was fine...Now i felt like HP was back so i decided to test for it. I was tested via an igM blood test and the result was negative..The question is was this igM test reliable or should i do a stool test? P.S there are no breath test in my state.
Re: Question on HP test
IgM is normally tested for something that you recently acquired.
IgA or IgG should be the appropriate test.
Nevertheless, if you had H. pylori, you can have IgG for months or even years.
Therefore, blood test is never the test to check if you still have H. pylori.
Please get another test, either breath or stool test, to verify your infection.
What a helpful post! I receive a lot of important information from you. Thank you so much!Helico_expert wrote: Thu Jul 13, 2023 7:12 pm IgM is normally tested for something that you recently acquired.
gladhyundai
You should still have blood tests or other tests to be able to evaluate more objectivelyLifeIsShort wrote: Thu Jul 13, 2023 1:40 am A year back i was declared HP positive via biopsy(endoscopy)..i took the triple therapy and i was fine...Now i felt like HP was back so i decided to test for it. I was tested via an igM blood test and the result was negative..The question is was this igM test reliable or should i do a stool test? P.S there are no breath test in my state.geometry dash
accountupset
The reliability of different tests for Helicobacter pylori (H. pylori) can vary, and choosing the right test depends on several factors, including the type of test available and the clinical context.
geometry dash
geometry dash
Kioslap
If you want to know which test is best, you have to consider a number of things, such as the kind of test that is accessible and the clinical setting.
andreeone23
A stool antigen test is generally considered more accurate for detecting an active H. pylori infection post-treatment, as it checks for the presence of H. pylori directly in your digestive system.LifeIsShort wrote: Thu Jul 13, 2023 1:40 am A year back i was declared HP positive via biopsy(endoscopy)..i took the triple therapy and i was fine...Now i felt like HP was back so i decided to test for it. I was tested via an igM blood test and the result was negative.. fnf The question is was this igM test reliable or should i do a stool test? P.S there are no breath test in my state.
Sophie1111
I'm really sorry to hear about your concerns regarding H. pylori. While an IgM blood test can indicate a recent infection, it may not always be the most reliable method for diagnosing an active H. pylori infection. Stool tests are generally considered more accurate for detecting ongoing infections. However, it's best to consult with your healthcare provider to determine the most appropriate testing method for your situation. They can provide personalized advice and recommend the best course of action based on your symptoms and medical history. And when you need a break from all the worry, taking some time to relax with a game of agario might help you unwind.
agario
agario
emelialucass
They are able to offer tailored guidance and suggest the most appropriate actions considering your symptoms and medical background retro bowl
nevisalexander
It's great to hear that you completed the triple therapy successfully! Regarding the IgM test, while it can indicate a recent infection, it's not always the most reliable for detecting H. pylori, especially after treatment. Since you’re concerned about a potential reinfection, a stool antigen test would be a more accurate option if available. If not, discussing your situation with your healthcare provider might help determine the best next steps. Wishing you the best! dummies world cup
