Low lymphocytes?
Callum
Low lymphocytes?
Post by Callum »
I’m currently half way through my 7 day triple therapy treatment for Helicobacter and symptoms aren’t improving but I know to trust the process so I’m sure I’ll start seeing improvements soon
I’ve been struggling since Christmas Day when I felt terribly ill, shaky and was sick, I went to my GP early Jan (symptoms - globus sensation - Nausea - loss of appetite - losing weight )they prescribed omeprazole 40mg 2x daily for 2 weeks, which didn’t help so I went back, they said to drop it down to 20mg 2x daily for 2 weeks which didn’t help either
Then 3 weeks ago I was at work and when I finished something hit me like a ton of bricks, i had terrible fatigue and I went incredibly dizzy anytime I wasn’t in a dark room, I’ve been off work since then and now it’s turned into lightheadedness and faint rather than dizziness, I can manage it if I am in bed watching tv but if I go for a walk longer than half a mile I get all lightheaded again and have to turn back
When it happened I phoned 111 and went to the hospital and they did some heart tests and blood tests and then my doctor did a FBC , everything was in order except I had low lymphocytes and was told to go for a Covid test, so I went for one and it was negative then was paranoid so I went for another and also negative.
My h.pylori test came back positive on Wednesday so I’m hoping that it’s all interconnected as my doctor said they don’t think my symptoms are typical of helicobacter, but fingers crossed 🤞
Anyone else had anything similar?
Callum
Re: Low lymphocytes?
agree with your doctor. H. pylori's symptoms are usually focus on the digestive system. Then again, it's also associated with iron deficiency, which is correlate with nausea. But I assume your blood test did not highlight iron deficiency.
Callum
Post by Callum »
Correct, FBC showed nothing unusual except the low lymphocytes
Callum
Post by Callum »
Would it be okay to take iron supplements while taking triple therapy for helicobacter? Or taking them after treatment?
you probably dont need additional iron pill as you have sufficient of it.
Like the doctor said, your symptoms may not because of H. pylori. Hopefully the strong antibiotics can get rid of other pathogens that is causing it.
Callum
Post by Callum »
Thank you for your replies Helico_Expert, they are much appreciated , one last question if I may, I am taking 30mg of lansoprazole 2x daily along with the antibiotics for 7 days, after this treatment do I drop down dosage to one 30mg lansoprazole on a morning for a month during recovery phase?
after you completed your 7 days treatment, you can gradually stop your lansoprazole. Perhaps change to once a day for a week, then alternate days, then stop.
monitor your own symptoms. if you think you cannot reduce the dosage, because the reflux or any acid symptoms keep coming back, then you can go back to 2x a day for another week.
Callum
Post by Callum »
Are there any known links between Helibactor or PPI use and low blood sugar? As my non gastric symptoms , lightheadedness and dizziness are compounded when I am either exerting or when I am hungry and although still there, they are much less noticeable after meals
H. pylori and PPI can affect the appetite. Some people may find certain food too sensitive and avoid them.
H. pylori is also link to iron deficiency, which then lead to "lightheaded" symptoms.
PPI is generally safe. Long term (more than a year) use of PPI may lead to calcium deficiency in bone.
Callum
Post by Callum »
I’ve seen that people are told to be off PPI for 2 weeks before a test, when I was told to get my test I was on PPI for a month straight, I know they can give false negatives but can they give false positives?
My lightheadedness has now manifested into incredibly painful headaches when i am moving and a dull headache when i am sitting still
I think I am going to double my lansoprazole dose to 30mg in morning and 30mg in evening as my symptoms haven’t changed at all and have only got worse since I ended my triple therapy ( 10 days ago )
