Gastritis after Pylori eradication
as_correia
Post by as_correia »
Hello
My symptoms started 2 years ago, with many difficulties in my voice, sometimes I couldn't even speak (I'm a clinical psychologist I use very much my voice) but I always thought that it was a problem due to a incorrect use of it. Last year in the summer I developed a very severe amigdalitis and I had to take antibiotics. One week later and in the end of the antibiotics I couldn't speak, and went to the otolaryngologist to see if I had something in my vocal cords. The doctor told me that I had the esophagus inflamed and it should be due to the stomach and maybe GERD.
I went to the GI and we schedule a endoscopy, he made a biopsy and the results were positive for pylori and a gastritis, after that I started the treatment, amoxicillin+ claritromicin+nexium - 14 days 12/12 hours.
I finished the treatment and according to GI I stoped the Nexium to make the oral test to see if I have pillory, and he told me to take esoxx one that is a protector of the stomach because of the testing. the result came negative 0.99% delPDB, positive are superior to 5%, so I believe is not a false negative.
During this period between diagnosis and the oral test I got a urinary infection and 2 weeks ago I got a allergic reaction with a unknown cause, I had a urticaria and libs, yes, hands all swollen and difficulties in breathing something like asthma. I had to take cortisone and then a anti histaminic. those meds, aggravated my symptoms of acid. I started to take PPI - nexium, 25 mg in morning and esoxx sos, but my burning and my acidic in the throat are not improving well.
I started a diet with no consumption of lower PH foods, I felt some improvements in begging but after 4 days the acid started again.
My question is: a friend of mine that is GI (not my GI I cannot go now because of COVID-19) told me that gastritis and GERD are two different diseases, and GERD is normally chronic :( I would like to ask if someone here had GERD as a consequence of pylori and if someone could reverse it.
And besides PPI if there is other treatment for it.
Thank you
Re: Gastritis after Pylori eradication
H. pylori can lead to acid reflux (GERD).
You have taken the triple therapy treatment to get rid of H. pylori, however, you did not mention about the follow up check to see if the treatment work. So perhaps you should try book a time (after covid) to see GP to get H. pylori test out via breath test of stool test.
I assume your symptom improved after the triple therapy. if so, even if the treatment fail, at least you know nexium helped. Then, you can continue nexium to control your current GERD symptom.
as_correia
Hello Helico
Thank you for your answer. I already made the breath test, came negative with those results:
negative 0.99% delPDB, positive are superior to 5%, so I believe is not a false negative...
After the treatment I had some episodes of GERD but occasionally, but after taking antibiotics and the other medications (cortisone and and anti histaminic) my GERD symptoms started to be very very intense. Now im in nexium in the mooring and esoxx after meals when I cannot support the acidic in the throat. I have not felling better and sometimes I think if is better to take more Nexium...
Regarding your experience the GERD symptoms because of the effects of Pylori are successfully treatable? I have reading that GERD is due to the lack of acid in stomach, what is your opinion?
Thank you very much
Ana
GERD can sometimes happened after eradication of H. pylori. Perhaps due to the stomach or the esophageal sphincter being irritated during the treatment.
GERD is commonly associated with acid reflux. So it is important to control the acid to prevent damage to your throat and teeth.
GERD is hard to go away, i dont have the exact stat with me, but some people does go back to normal after weeks, months or years.
