Fasting longer & C13 test result
Adam
Post by Adam »
Would fasting longer than the recommended time, affect C13 test result?
Re: Fasting longer & C13 test result
nope. as long as your stomach is empty, then only we can confirm that the breath test is reacting on the bacteria, not your food.
