Pylori Blood Test Negative?
dominover
Post by dominover »
I have a gnawing feeling in my upper left stomach area, just below my rib cage. Seems to be worse when my stomach is empty and if I haven't eaten all day. It seems to have started after I breathed in, an possibly ingested, some caustic soda 3 months ago now. Initially I breathed in the vapours and then it may have splashed into some cups and I eventually drank from those cups. My silly mistake of course.
I was surprised that it seems to have as much damage as it has but I began to think that given a myriad of other symptoms I have, I could have damaged an already thin stomach lining from pylori.
I suffer from terrible bloating (for half my life). My body seems to act like a diabetic but I don't have diabetes and all tests come back healthy. I have a gnawing localised pain in my upper left stomach (just below the rib cage bottom rib). I get stomach problems easily (often getting sick from something I've eaten). I seem to have become intolerant to bread and oats (they give me terrible brain fog). If I eat too much of one thing (at one point it was tomato's) I become alergic to it.. This comes in the form of terrible brain fog and vision problems.
I'm actually quiet amazed that I don't have pylori so I'm asking any of you two questions.
1 - Can a pylori blood test pass back a false negative?
2 - If this is not pylori, then what could it be if I have had it for over 3 months now?
(I do not use NSAIDS or any other medication and haven't in 20 years at least).
45 years old, male.
Re: Pylori Blood Test Negative?
it's pretty hard to get false negative from blood test. Then again, no test is 100%. If unsure, you can always get breath test to double confirm.
Nevertheless, you sounded like you became intolerance to gluten. Maybe you want to try a week without gluten to see if your symptom improve. You might want to see a specialist to discuss about this.
dominover
Post by dominover »
Hi. I thought of that so I haven't eaten gluten foods for some time now. Problem is still there.
I even had my pancreas tested. Its fine.
