Tests and symptoms
HPI
Tests and symptoms
Post by HPI »
1. If I had taken mosapride citrate tablets 1 week before an endoscopy and a 14C-UBT test, would they affect the tests? If yes, how?
2. If I started blowing the UBT test kit 5-10 minutes instead of 15 minutes after taking the pill, how would it affect the result?
3. If a test kit was just left on the table for 15 minutes before it was slotted into a machine, I guess this wouldn't affect the result since some clinics have to deliver the test kits to a lab?
4. For those with bad breath, how severe was it? Room filling? From the mouth only or from both the mouth and nose? People who had eradicated HP, did the BB go away once your HP was gone?
5. Does anyone have LPR symptoms instead of GERD? (No heartburn, but have lump and burning sensation in the throat)?
frostyfeet
Re: Tests and symptoms
Post by frostyfeet »
I can answer #4:
See my journal here:
viewtopic.php?f=33&t=205843
My BB came from the throat down and only through the mouth. The BB went away on day 1. My last antibiotic dosage was a week ago and so far, my BB hasn't come back. Crossing my fingers that it's gone for good.
Best of luck to you!
Mosapride won’t affect the UBT result.
If you blow the balloon too early, you may get false negative because of not given enough reaction time for urea to break down into CO2 and absorb into your blood stream and exchange in your lung.
Once the breath is collected, it can stay on bench for a very long time. You can check the half life of C14
The bad breath is very subjective. It won’t fill the room. But the person you speaking to can sometimes smell it. Antibiotic usually remove the problem. However if you have a bad tooth and the bad breath is because of the bacteria living there, then the bad breath will come back.
Yes, you can sometimes feel a lump behind a throat. Some members in this forum mentioned it before.
HPI
Post by HPI »
Helico_expert wrote: Thu Apr 19, 2018 9:58 pm Mosapride won’t affect the UBT result.
Thanks for the answers! My main problem is actually the constant bad breath. The LRP symptoms can be controlled by maintaining a strict GERD-friendly diet.
Dentists couldn't find any problem. They did a dental x-ray, a few cleanings, and replaced the old fillings. They said it's likely a systemic problem since I have nasal bad breath too.
ENT did a few nasal endoscopies and a sinus CT scan, but they couldn't find anything too.
I did 2 upper GI endoscopies about 2 years apart. Both said I have mild gastritis and mild erythema in the antrum. The 2nd endoscopy also showed a comparative lot of yellowish secretions in the fundus and some signs of past bleeding in the antrum. However, the doctors said all these were no big deal.
During the 1st GI endoscopy, a biopsy was taken to test for HP infection and the result was negative (might not be accurate as I had taken rifaximin a few days before). About a year later, I was tested positive for HP infection by UBT (250dpm). 4 weeks after treatment, I did another UBT test and it was negative (10dpm). Right after the 2nd endoscopy, I was asked to do an UBT again (0dpm). However, this UBT might not have been done properly as my companion might have timed the 15 mins from the time I came out of the theatre instead of from the time I took the pill.
Should I do another UBT properly or is there anything else I should test for? My doctors are all out of ideas.
you have done UBT twice after the treatment and both negative. I think the chance of false negative is very little.
Since you are free of H. pylori now and if you still have bad breath, it's probably due to something else. I can only suggest a constant mouth wash to remove oral bacteria.
