After hylori
After hylori
Hi im new here never had tummy problems went to docs with very bad chest back and arm pain ( thought i was having heart attack )
was diagnosed with hpylori and started triple terapy.First 2 days felt amazing but on the 3rd day all went to hell vomiting headaches lightheaded aniexty panic attacks which ive never had .Finished treatment and endoscopy came back clear for hpylori but 3 months later im still very sick chest pain constant burping can only eat plain tiny meals and have lost over 35 pounds which i couldnt afford to lose im now skin and bone only 38kg and im 5 foot 6
my doc only says eat eat but when i do eat im in so much pain in my chest
im on rainitidine 150 3 times a day as ppi s make me so ill endoscopy also said hiatus hernia and mild gastritis is this all from hpylori as before all this 4 months ago i was running half marathons now a walk to my bathroom leaves me breathless anyone experienced the same ?? Thanks in advance
Re: After hylori
you are experiencing side effects of the antibiotics on the 3rd day on wards.
how many weeks between end of treatment and endoscopy? if you have not stopped treatment long enough, there may be too little bacteria left to give positive results from endoscopy. did your specialist order a histology or CLOtest?
Ranitidine is good. if you may want to do another breath test to find out if you still have H. pylori. You can continue ranitidine until the day before breath test.
lastly, which PPI give you side effects? you might want to consider other PPI, eg. rabeprazole.
Re: After hylori
I stopped ppi about 1 week after antibiotic treatment and endoscopy was about 5 weeks after that i got no information from them only hiatel hernia and gastritis still waiting on follow up app but its going to be another 15 weeks
Re: After hylori
Sorry forgot about ppi s they tryed me on nexium which i ended up in hospital after lanzaprole esmoprazole and the most recent was pantroprazole all left me lightheaded nausea and really bad headaches
Re: After hylori
I see. from your description, I think your specialist is doing the right thing. Unfortunately you'll have to continue on Ranitidine until you are better. There is one more PPI that you can try, Rabeprazole. It is metabolised differently compare to other PPI that you mentioned. perhaps you can give that a try.
Re: After hylori
I ll have to tough it out for nxt couple of weeks till i see the specialist again thank you
Re: After hylori
Hi again four months since my last post and still symptomatic but not as bad just got word back from second endoscopy and breath test i still have hpylori so back on treatment again tommorow
this is a horrible bacteria hopefully this time i can eradicate it for good
Re: After hylori
What did they do for your hital hernia
Re: After hylori
Berorion wrote: Mon Jun 18, 2018 3:22 am i still have hpylori so back on treatment again tommorowthis is a horrible bacteria hopefully this time i can eradicate it for good
A few tips:
- Higher PPI have higher cure rate. We give 20mg Rabeprazole 3x a day.
- H. pylori never become resistant to Amoxicillin and Bismuth. These two drugs can be reused all the time in high dose.
- Never repeat the other antibiotics you had previously
Re: After hylori
Nothing yet just finished having the last tests done this week endoscopy ,phd test,osophugal mamatry, barum swallow so back to gastro this friday to find out what there going to do they have mentioned an operation depending on test results
