Where Can I get gene expression library
henrrymo
Post by henrrymo »
Exon trapping and targeted regions trapping are commonly used in the second generation sequencing methods, which require a one-time synthesis of tens to millions of primers. If use the traditional method for synthesis of primers, the cost is very high. And now I really need this. where can I get the gene expression library?
Re: Where Can I get gene expression library
I am sorry, your question is too advance for me. Why do you need gene expression library by the way? cant you use illumina truseq and sequence all the expressed RNA?
