After a year repeated gastroscopy
dioxnet
Post by dioxnet »
After a year repeated gastroscopy, there are no complications, nothing, Dr.
He says, wants to see as I continue gastritis, erosive duodenitis (bulb)
and if you see no complications, the diagnosis will .....
that I do, my nerves, anxiety, fear, anger ...
produce acid ....
which has already seen several cases with negative H. pylori and stomach problems I
because of anxiety, strees
they think, I repeat the test, it has only been a year
this time sedated me :)
I did not want to test blood ...
I'm not convinced
it is my nerves, and if so I have a big problem more than H.pylori
because I do not know how calm myself :(
history
2 test c13 negative
biopsy test urease negative
I do repeat endoscopy?
Re: After a year repeated gastroscopy
If you did the C13 UBT the right way, it is very sensitive and accurate. since you got two negatives, i think the chance of you actually having H. pylori is low.
since your previous endoscopy showed no complication in your stomach, i think there is no need for further endoscopy.
if you are still having gastric symptoms, you may want to take some PPI to control it.
lastly, if you are having a lot of anxiety, you'll need to calm down. read some books, divert your attention, think of something nice and positive. Anxiety can lead to stomach problem which we dont know why.
dioxnet
Post by dioxnet »
in the previous endoscopy found, gastritis, erosive duodenitis and
sorry but the translator use, why not understood well
H. pylori is normally the reason for gastritis and erosion. However, since you are breath test negative, you probably have some kind of food allergy that cause the gastritis.
have you been taking NSAIDs? (for example ibuprofen, aspirin, anti-inflammatory pain killers)
dioxnet
Post by dioxnet »
never taken (for example ibuprofen, aspirin, anti-inflammatory pain killers)
I neither smoke nor drink alcohol, coffee from 15 years 1 week ago
my diet is only pasta, broccoli, turkey, pork, bread, eggs, fruits
yogurt, water, ho no more
My father tells me quer not take vegetables,
 diarrhea give the (my father)
I practice
6 Days moderate sport, fitness and running 35km a week
no weight loss, good muscle mass
I had hepatitis C, but I treated and I am cured, 15 years ago
before drinking and smoking and drugs, now nothing, I changed my whole life
So if I have many problems, they eat me .......
nerves, anxiety, hypochondriac, anger, rage, fear
normal for a parent, no job, no money
and people just want to step on you more and more ....................
when sick for the first time, the first symptom was joint pain, as when you have fever, diarrhea poor digestion (functional)
I guess it's the feeling when the erosina duodenum ....
hinchadisima belly, and much much air per month
but air with bestial pain, then everything ..... Reducio
and does not war but notes, let omeprazole, I returned to drink coffee and eat chocolate and stress and a month .... like a cold and mushy and black stools .....
omeprazole and take off my joint pain after meals
black stools were in 4 days this was fast
first of all, if you are a carrier of Hep C, it's a life-long infection. I think very rare that people have it totally eradicated. So you'll need to double check on that.
Otherwise, you are young, fit and healthy. You are also free of H. pylori. I am not too sure why you have the erosion and gastritis in your stomach. Do you know if you have any food allergies?
