C13 / C14 what is the difference !
kelthuzad
Post by kelthuzad »
i want to equip my clinical laboratory with the HP urea breath test then i got to think : C13/C14 !!!
i don't seem to find the point behind making c13 or c14 since they seem to have same performance .
i thought at first it was a safety matter (radioactivity of C14 even if it seems negligible)
then after hours of digging i found that C14 is cheaper and easier to handle then C13
anyone have a clue please ????
Re: C13 / C14 what is the difference !
C13 can be found naturally in your body. That's why you need to measure your baseline before taking the C13 pill. Yes, you are right it is harder to process and without experience, result can easily be messed up. Because C13 is simply everywhere.
C14 on the other hand, it's radioactive, and which in my opinion, less likely to mess up and more accurate. The radiation is very low and it is even approved to be used by pregnant women and children. Nevertheless, it is still a radioactive element and many people is afraid of it.
Let me know if i have not answered your question.
michaeljonson
Post by michaeljonson »
Helico_expert, thank you for explaining the difference.
Legacy ER & Urgent Care
lily
Post by lily »
is the c13 will get out from body after eat ?
C13 is naturally present in your body. That's why you need to collect two breaths. The first one is to measure the amount of C13 in your body. then you are asked to take the C13 pill and collect the second breath to see if your C13 count increased.
lily
Post by lily »
thank you replied me。i just so worry C13 will hrut me after many many years and i will get very bad sick 。 i can not have no more kids beaucse the kids many have problem you naver know
lily
Post by lily »
Do you know if to much c 13 is bad for your body and how much is to much? Do you know how long it take to expell from your body and does it come out in your pee or does it come out some other way? Thank You very much.
lily
Post by lily »
Is it bad to have to much C13 in your body and how much is to much? Also how does it expell from your body, do you pee it out or does it come out some other way? Thank you very much.
It really nothing to worry about. C13 is natural. It’s everywhere in the environment. You cannot avoid.
There isn’t a lot of safety information about C13 because it’s generally regarded as safe.
C14 on the other hand, experiment has shown that over 90% of the C14 is breath out within an hour. Almost 99% will be out the body within a day.
lily
Post by lily »
C14 out the body one day just for people who have PH or for everybody ? thank you very much for you all help
