High Dose Dual Therapy with AMOXICILLIN & PPI
emma frost
Post by emma frost »
Does anyone know if this form of therapy is working? I saw a study but I'm not a scientist or Doctor so..
Thanks for Reading!
Semper Fi!
emma frost
Re: High Dose Dual Therapy with AMOXICILLIN & PPI
I located this article:
http://www.ncbi.nlm.nih.gov/pubmed/25460556
Can anyone speak to HDDT?
i am a bit skeptical on this data. Dual therapy has been tested many times previously and showed low eradication rate. However, if you can tolerate triple or quadruple therapy, I think you should not consider the dual therapy.
Nevertheless, if you dont mind trying, the dual therapy with amoxicillin will not cause resistance. So if it doesnt work, you can always go back to triple or quadruple therapy.
http://www.ncbi.nlm.nih.gov/pubmed/9576452
