Allergies, Hives & Indigestion
gabriellelea
I just finished the 7-day triple therapy on Friday i.e. Amoxicillin, Metronidazole and Omeprazole to eradicate H.pylori. It all started back in the spring when I began getting hives/skin rashes, which itched like mad. I was given anti-histamines. I took these every two or three days, but it became chronic and just when I was about to be sent to a dermatologist, severe indigestion began, or at least a horrid lump in my throat. At first, this was just after meals, but it soon became 24/7. I also started having really bad allergies i.e. sneezing and wheezing (I am an allergic type it has to be said). I researched and found H.pylori as a possible cause and after discussions with my GP, I had a stool sample analysis carried out and it was confirmed that I did indeed have this bacteria in my body. The treatment was hellish as I had terrible side effects (diarrhoea, nausea, headaches and metallic taste). However, I persevered and completed the course. I also had to take anti-histamine at least once during this week to stop the miserable itching. I had a blood test during the treatment week and this came back showing my white blood cells were extremely low (have to be retested in six weeks).
My questions...
I finished the treatment on Friday and I largely feel the same as before. I can still hardly eat anything without the lump in my throat feeling. The allergies are also as bad with the same rashes and itching, wheezing, runny nose, red, itchy eyes, etc. The GP just said to come back if my symptoms didn't disappear. I think I have read I should wait at least four weeks. Is this correct? Any ideas on whether the allergies/hives will take that long to go too. I can barely function at the moment without anti-histamine. I am an ex-top class athlete and I train really hard in the gym. However, this has all had to stop the last few weeks due to feeling so bad.
My questions...
Re: Allergies, Hives & Indigestion
H. pylori is now suggested to have reverse effect on allergies. Meaning, people who are infected with H. pylori are less likely to be allergic. However, it's still a hypothesis. But that's what most scientist believe now.
to check if your h. pylori still exist, you have to wait 4 weeks without antibiotics and PPI (and anything that will kill H. pylori and reduce acid). I suspect your allergies are not related to H. pylori.
gabriellelea
So you think that H.pylori potentially making my stomach more permeable to food substances leaking out and thereby causing an allergic reaction is unlikely? There have been links to high levels of histamine and stomach acid, have there not? Is it possible to be allergic to H.pylori itself? Some research does seem to suggest that skin rashes clear up after H.pylori is eradicated.
Thanks for clarifying about the 4-week wait. I am now just taking probiotics.
I do hope it is that simple. No, H. pylori does not making your stomach more permeable to food substances leaking out and thereby causing an allergic reaction. However, it does damage the mucous producing cells and hence your stomach loss the mucous and the stomach acid start digesting your stomach, which may lead to ulcer.
H. pylori is associated with higher stomach acid level. Not too sure about histamine level though.
I dont think it is possible to be allergic to H. pylori. It has been with human hundred of thousands years ago. It has evolved together with human ever since.
Skin rashes clears up... I think that is more related to antibiotics killing other unknown bacteria infecting the skin. H. pylori can only lives in the stomach, not on skin.
gabriellelea
Thank you for your clarification and thoughts. I guess I just find it coincidental that they both started around the same time. It may be my immunity is just low in general at the moment.
Well, fingers crossed the first treatment did it. I had a bad night with reflux type feelings, but I'll see out the next few weeks before getting checked again. Thanks again.
gabriellelea
It was this that I was referring to on this very site: http://www.helico.com/?q=WeirdSyndromes
" Patients with HP have increased permeability of the gastric mucosa and so are potentially exposed to unprocessed antigens from food. This might predispose to immune problems. H.pylori antibodies cross react with several tissues in the GUT so autoimmune states are possible with H.pylori. Weird skin rashes have occasionally disappeared when H.pylori was treated."
If you are looking for fast success in pass4sure.co.uk then join today to find complete The College of New Jersey resources.
newhpyloridiag
Did the Doctor investigate/figure-out why the WBC count is low? When you have an bacterial/viral infection, your immune system should be acting and the WBC count will be at the high end of the normal range or higher than normal.
Did the Doctor figure out about the lump in the throat feeling? Since you have sneezing and probably cold, may be mucus is formed in your throat.
Hives and rashes causes are
Allergic reactions, chemicals in certain foods(nuts, chocolate, fish, tomatoes, eggs, fresh berries, and milk), insect stings, sunlight exposure, or medications.
No way related to HPylori.
Take a breath/stool test 30 days after the treatment to check for HPylori eradication. Before the test, stop using PPIs for at-least 1 week.
gabriellelea
I think the problem is that I had the blood test after I had already started the treatment (due to scheduling difficulties) and so a low WBC can be a side effect of antibiotics and anti-histamines from what I've read. She asked me to do another blood check in 6 weeks time to check on the WBC then.
I am probably just describing in my own way the indigestion/reflux/ belching when I say about the lump in my throat feeling.
If my immune system is low, then my sensitivities that I usually control are going to be heightened I would guess.
I have read a number of studies that seem to suggest that H.pylori can lead to skin rashes. I also read this today: It has also been proposed that Helicobacter pylori (H. pylori), which has an immunogenic cell envelope, may play an indirect role in the etiology of chronic autoimmune urticaria by reducing immune tolerance and inducing autoantibody formation. However, it is important to note that the limited number of studies conducted in this area have yielded conflicting results [7,8]. And this very site suggests it is possible as I quoted above, so I am not sure how you can be so certain.
Thanks for replying and your input. I will take a stool re-check in a few weeks. I am no longer taking a PPI since the 7-day treatment ended, as they don't work on me anyway.
Hey I know this was posted a while ago but I'm really hoping for a reply. I too suffer from chronic hives and am wondering if h.pylori might be the culprit (im going to get tested for it soon). Just wondering how your treatment went and whether it did end up treating your hives, thanks!!
