Could these symptoms be H Pylori
DanielPine
Post by DanielPine »
Burp A lot. Fart a lot. Minor acid reflux, worsened when I eat unhealthy. Poo 2 times a day and find it hard to hold in. Tingling in esophagus and throat. Food often gets stuck in esophagus. Hot Acidic farts (I know, its gross). I get random nausea for 1 or 2 seconds, normally between 0-2 hours after eating. Occasional acidic almond taste in mouth. I sometimes feel randomly tired, this might be normal for a teenager though. I also have a white coated tongue and bad breath. The white coat reduces when I take probiotics. I have had these symptoms since a young age
Re: Could these symptoms be H Pylori
the bloating and reflux is probably associated with H. pylori. other than that, probably relate to wrong normal flora in your stomach. If you are positive for H. pylori, the triple therapy will probably give your guts flora a fix too.
