False Negative Blood Test??
Blood tests (for antibody) are used to screen for H.pylori. They remain positive for many months after treatment so can only be used as the initial test. Urine antibody is a "pregnanacy style" urine test. Accuracy is slightly less than blood tests. A negative blood test is good evidence that Hp is NOT present. Use it to exclude the diagnosis (but no test is 100% perfect remember).
new2hp
Post by new2hp »
Two weeks ago I had a negative blood test for H. Pylori. I had an EGD done last week and the biopsy was positive for H. Pylori. Has this happened to anyone else? I'm wondering which was incorrect. I know the biopsy should be the correct one but I know pathologists make mistakes too. Just wondering how often this occurs because I can't find much online.
Re: False Negative Blood Test??
no single test is 100%. but it is very rare that blood test will fail. nevertheless, in this situation you'll need another test to confirm. have you got a histology test? or Culture?
new2hp
Post by new2hp »
I don't know, would they do that on the biopsy they took?
new2hp
Post by new2hp »
My Diff-quick stain was negative but my HP Fast was positive
interesting. so you have 2 negative and 1 positive tests. I trust HP Fast better. however, there are false positives in HP Fast. How positive is your HP Fast test? border line positive or high positive? what did your endoscopy report says? any inflammation?
if you have no symptom, no inflammation, no ulcer or anything significant, you can ignore it.
Return to “Antibody type Tests (blood or urine antibody)”
