C13 / C14 what is the difference !
Re: C13 / C14 what is the difference !
it is the same for everybody.
the dose of C14 is so low, it's almost equivalent to 2 hrs standing under the sun. Because it's so safe. it's being approved by FDA for pregnant women and children.
Have a read from Prof Marshall's early article about C14 dosage.
The effective dose equivalent (global mean) to an average person from natural sources was recently reported by UNSCEAR to be 2.4 mSv/yr. Approximately 800 C14-urea "microdose" breath tests (37 kBq per tests) would generate the same effective dose equivalent.
http://jnm.snmjournals.org/content/34/5/821.long
emmbritt123
Post by emmbritt123 »
I'd like know know how to get the breath test done in England. No one seems to know what it is here. It's not done on NHS and I'm willing to pay for it. Help !
it's amazing no one knows about urea breath test in England.
anyway, I have found this from NHS website.
https://www.hey.nhs.uk/patient-leaflet/ ... eath-test/
