Alternatives to PPIs
Nmcormick066
Post by Nmcormick066 »
Hi there, my main symptom of helicobacter is acid reflux. I don’t know if it is causing me to have low acid but all I know no matter what amount of PPI I took it did t relieve the symptoms. So someone had mentioned on here about it lowering my acid further which was causing my continued reflux. Just wondered if anyone had anything other than ppi that was good had relieving acid reflux symptoms. Waiting my breath test results and fairly confident it’s not been eradicated as symptoms are just as bad as ever! Is gaviscon liquid better than the tablet? If I test positive this time that will have been 3 failures to eradicate.
Re: Alternatives to PPIs
First of all, it's important to make sure that you are free of H. pylori, otherwise the symptoms are just going to keep coming back.
second, everyone has different metabolic rate against different brand of PPI. If you dont find your current brand good, change it. try out Rabeprazole or esomeprazole.
Nmcormick066
Well I just got the results of my breath test today and after 3 attempts I have just got a negative result, so I am delighted! Although now I’m worried why still the reflux symptoms???
Congratulation! 3 time's a charm..
it's common to have the symptoms after HP eradication. It's actually the damage caused by HP that gives you the symptoms. So you need to give time for the healing. Depending on the damage done, the recovery may take weeks, months or years. If you find PPI helpful, just continue on. You can re-check for your HP status in a few months time.
Meanwhile, you may want to make sure everyone living under the same roof is also free of HP to prevent reinfection.
yadirarodrig
Post by yadirarodrig »
If PPIs aren’t helping, liquid Gaviscon (alginate-based) is often better than tablets because it forms a physical barrier (“raft”) that blocks reflux rather than reducing acid. Many people find the liquid works better for symptom relief. Don’t try acid supplements (like betaine HCl) while H. pylori is possible — that can worsen irritation.
If this is your third eradication failure, you should ask your doctor about antibiotic resistance testing or quadruple therapy and make sure PPIs were stopped 2 weeks before the breath test, as they can affect results.
Sinaki
Post by Sinaki »
Nmcormick066 wrote: Thu Oct 14, 2021 12:03 am Well, I just got the results of my breath test today and after 3 attempts I have just got a negative result, so I am delighted! Although now I’m worried why still the reflux symptoms???
Regarding Gaviscon, many people find that the liquid form works better than the tablets because it creates a thicker protective barrier on top of the stomach contents. However, individual results vary, and it's important to follow the instructions on the label.
