How do you think about this second treatment?
fjo
Post by fjo »
First of all, thank you for your comment in advance. I’m glad that I found a place where I can get opinions from several experts.
I’m just about to begin my second treatment for Helicobacter Pylori. I already have prescribed drugs in my hand, but I’d like to check if this prescription seems appropriate. Of course, the drugs were prescribed by a gastroenterologist. However, I’m curious how the members in this professional forum think about.
Some Background: I’m from South Korea where Helicobacter Pylori is very prevalent. (It’s so prevalent such that Prof. Marshall starred in a probiotics yogurt advertisement.) Here is a record of my stomach examinations.
2012: Had EGD for the first time with Doctor A. Diagnosed with chronic superficial gastritis. Biopsy was done and diagnosed with h. pylori. Since chronic superficial gastritis and h. pylori are common in S. Korea, the doctor didn’t consider them to be problematic. She said she had chronic superficial gastritis too.
2013: Had EGD with Doctor B. Asked the doctor not to do a biopsy as I already knew I had h. pylori. Diagnosed with chronic superficial gastritis as expected.
2014: Had EGD with Doctor C. I told him that I have h. pylori and he told me that it should be treated as it does no good to my health at all. He did a biopsy to verify that I have h. pylori and prescribed the following drugs for the first treatment.
Rabeprazole Sodium 20 mg - 2 times per day for 10 days
Clarithromycin 500 mg - 2 times per day for 10 days
Amoxicillin 1000 mg - 2 times per day for 10 days
2015: Had EGD with Doctor D. Asked him to do a biopsy to see if h. pylori had been eradicated. H. pylori was still there, but this doctor advised me to save the second treatment for serious stomach condition such as ulcer. He was concerned that if the second treatment fails and h. pylori develops resistance against antibiotics, I would have difficulty in case I get a stomach ulcer or something else.
As a side note, National Health Insurance Service of S. Korea does not recommend nor reimburse treatment for h. pylori unless the patient has certain stomach conditions. For this reason, Korean doctors are divided between whether h. pylori has to be always treated or not.
2016: Had EGD with Doctor E. No biopsy done. Diagnosed superficial gastritis as usual.
2017: Had EGD with Doctor F. No biopsy done. Diagnosed with atrophic gastritis and acid reflux. Given that I’m in early 30s, having atrophic gastritis certainly sounds bad. Nevertheless, the doctor just told me to get EGD annually.
2018: Had EGD with Doctor C again. He told me that I had severe inflammations in the stomach. (I had heartburn and back pain, so it was not surprising.) He said my stomach was in transition from superficial gastritis to atrophic gastritis. Biopsy was done to verify that I had h. pylori and he prescribed the following drugs for the second treatment.
Tripotassium Bismuth Dicitrate 300 mg - 4 times per day for 10 days
Tetracycline HCl 500 mg - 4 times per day for 10 days
Metronidazole 500 mg - 3 times per day for 10 days
My dad was with me when Doctor C was telling me about the second treatment and he asked the doctor if 10 days was good enough. (He asked because his second h. pylori treatment was successful with 14 days of prescription.) The doctor answered that there is a negligible difference of cure rate between 10-day prescription and 14-day prescription and the doc just gave me a 10-day prescription.
My primary question is does this prescription look appropriate for a standard second treatment? I didn’t have antibiotic sensitivity testing, so I’m just asking in general. I don’t want to take insufficient drugs that may develop antibiotic resistance of h. pylori eventually.
I asked Doctor C if there is backup therapy in case this second treatment fails, and he answered there is. But I guess there is only a limited number of backup therapies remaining as h. pylori will become more resistant against antibiotics. If it were not for the risk of developing antibiotic resistance of h. pylori, I would have started the second treatment a long time ago. Frequent heartburn and occasional back pain are quite irritating.
If that second prescription does not seem adequate, I’ll see another doctor to get a different prescription based on what experts comment here.
Re: How do you think about this second treatment?
Thanks for the detail story. the second treatment you are having is a PBMT treatment or PYLERA. It's pretty good. look forward to hearing your updates.
fjo
Post by fjo »
Helico_expert wrote: Sun Sep 02, 2018 2:47 pm Thanks for the detail story. the second treatment you are having is a PBMT treatment or PYLERA. It's pretty good. look forward to hearing your updates.
Thank you for the reply. I'll post an update after I get a breath test several months later. Hopefully, it'll be cured this time.
helico_highBP
H Pylori vs Blood Pressure
Post by helico_highBP »
Hi All ,
Please advice
Emergency Instances : -
H Pylori Detected :
After 6 visits with Doctor I got chance to do breath test and got detected positive for H Pylori - which I was happy because I though at least they found something wrong and something they can work on.
H Pylori Treatment :
Now my treatment is complete where I got 3000 mg of Amox + Clarithromycin + Omeprazole(20mg*2) for 14 days .
Post H Pylori Treatment :
Feeling much better compare to past month , started driving , playing tennis a little bit but since yesterday I started getting more stomach acidity , bloating and cold sweat sometimes.. I also started experiencing Heartbits / fluttering kind of sensations but Apple watch still shows heart rate between 75 - 97 bpm.
Thank You
alicebobby
Post by alicebobby »
I appreciate the detailed narrative. You are receiving PYLERA, also known as PBMT, as your second treatment. It's not that bad. eager to hear about any updates.  retro bowl college
donna1205
Post by donna1205 »
What specifically about the gameplay loop felt uninteresting? Was it repetitive tasks, lack of challenge, or something else? Providing details would help your critique feel more grounded. Sprunki
Kuke698
Post by Kuke698 »
Thanks for the detailed explanation! I’m glad to know I’ll be starting PYLERA (PBMT) as my second treatment—honestly, it sounds manageable. Looking forward to any updates, especially about Retro Bowl College!
Jumpshot Guesser Game
biubiu
Dirs.cc
Post by biubiu »
Wow, that sounds like you've been on a wild gastro adventure! I feel like I need a map to keep track of all those doctors. But hey, if you're looking for a good resource while you navigate this, maybe check out for some helpful tools and insights.
shueam
Post by shueam »
To participate in discussions about H. pylori and its treatment on the forum, you must register as a user. If you encounter any issues with posting, registering, or logging in, please reach out to the admin at Marshall.centre@gmail.com with "Help needed for www.helico.com" in the subject line. Remember, advertising is not permitted, and the forum aims to provide accurate information and support regarding H. pylori. Additionally, if you have been diagnosed with H. pylori, please contribute to the symptoms survey to help gather important data. slope game
baseball bros io
