Any consumer polyclonal enzyme-linked immunosorbent assay (EIA) tests?
H.pylori bacteria in the stomach will pass through the bowel and parts of the bacteria will end up in the feaces. To detect the bacteria a feces sample (only 1 or 2 grams is required) is refrigerated and sent to the lab. In the lab antibodies are used to show up presence of bacter (called ELISA testing). These tests can be made in a dipstick form for near-patient diagnosis. the accuracy of these tests varies but is about 90%. This is a test for ACTIVE CURRENT INFECTION so it can be used after treatment to see if H.pylori is gone. It is also an easy one for little children as no needle is required and no fasting or other preparation of the patient needs to be done.
Alfred001
Post by Alfred001 »
Does anyone know of a consumer test that is based on enzyme-linked immunosorbent assay (EIA) polyclonal antigens?
Re: Any consumer polyclonal enzyme-linked immunosorbent assay (EIA) tests?
I think most diagnostic laboratory would have this test. It's not meant for home test. You need your blood to be processed to be tested.
Return to “Faeces Antigen Tests (stool samples)”
