I am going to try another antibiotic round, should I try using NAC for biofilm?
Larry Valery
Post by Larry Valery »
I read that NAC helps to eliminate biofilm created by H Pylori, seems like that's a possibility why I couldn't eliminate H pylori first round of antibiotics.
I'm still low stomach acid as well, I've tried using 25 Betaine HCL pills with pepsin without any discomfort in my stomach however my large intestine has gotten worse since the first antibiotic treatment. Probably due to my microbiome being nuked by antibiotics.
I'm waiting to schedule an endoscopy/colonoscopy with my GI doctor, I had to reschedule my other appointment.
My first treatment consisted of clarithromycin, metronidazole, and pantoprazole.
Re: I am going to try another antibiotic round, should I try using NAC for biofilm?
thanks for the update. you can perhaps include bismuth in your next treatment.
Bismuth can prevent antibiotics complication due to C. diff.
derlean
Post by derlean »
I can understand why the connection between H. pylori, biofilms, antibiotics, and changes in the gut microbiome would raise questions. It sounds like you’re taking a thoughtful approach by discussing these concerns with your GI doctor and getting the endoscopy/colonoscopy scheduled rather than trying to make too many changes on your own. Veck IO
