Weight loss & muscle gain!
Re: Weight loss & muscle gain!
I assume your question is also Helicobacter pylori related.
It's common for patients to gain weight after eradication of H. pylori. Because as H. pylori is gone, the stomach is healthier and patients appetite is usually improved.
Davidmike
Post by Davidmike »
Thanks for the tips here. Hope this will help to lose weight and gain muscle.
frostyfeet
Post by frostyfeet »
This seems like a spam post.
Davidmike
Post by Davidmike »
Actually I am totally new and don't know much about the supplements which helps to gain muscle and weight loss at the same time. If you know well please guide me. thank you!
jamespandy
Post by jamespandy »
Davidmike wrote: Fri Apr 20, 2018 7:34 pm Actually I am totally new and don't know much about the supplements which helps to gain muscle and weight loss at the same time. If you know well please guide me. thank you!
I am also a newbie like you. I would like to get some more details about weight loss. Thanks!
jerryjass
Post by jerryjass »
i was doing some research in weight loss then i found that turmeric is best for skin and weight loss but if you do take this 3 times per day.
https://explorediet.com/turmeric-curcumin-plus/
Atrix
Post by Atrix »
For weight loss try supplementing with spirulina.. It always works for me.. In regards to building muscles you'll need protein rich foods & some strength excercise..
WarrenEllison
Post by WarrenEllison »
Yes, by having a healthy stomach, you are allowed to eat everything. Just be aware of how much, not to gain weight. In my case, I had to face my anxiety before losing weight. I have no Helicobacter bacteria, but I was depressed due to a divorce. So I suffered a lot from this loss, but I knew that we do not anything more in common. So the depression and stress was the main problem why I couldn't lose weight. I needed the help of some specialist as
For one year, they worked with me to improve my mental health firstly and feel more confident in who I'm. As a result, I lost over 10 lbs, and I started to love myself more. I'm still divorced, but I truly believe that soon I will find my partner.
Connoleib
Post by Connoleib »
I think that after a lot of weight loss you should talk to your doctor before you start exercising.
Asminext
Post by Asminext »
Yeah, it’s pretty common to gain a bit of weight after kicking H. pylori since your stomach’s feeling better and you’re hungrier. If you’re trying to balance weight loss and muscle gain, I’d say focus on eating enough protein and doing strength exercises. That combo’s worked for me in the past. If you’re into yoga studio software or want something a bit easier on the body while you build up, I’ve come across one coolyoga studio software that helps you plan out your workouts. It’s helped me stay on track when I’ve needed a mix of strength and flexibility training.
