3rd therapy ongoing still positive
Re: 3rd therapy ongoing still positive
I guess I can explain it this way.
The four stages of severity.
1st stage, gastritis inflammation
2nd stage, metaplasia
3rd stage, atrophic gastritis
4th stage, gastric cancer
So you are still at the very beginning stage and should have H. pylori eradicated before your condition worsen. But you must not panic. Because each stage would probably take years to develop.
Navinavi
Post by Navinavi »
Thanks again Helico_expert.
Kayce008
Post by Kayce008 »
How are u@naninavi
Any headway with your treatment as I am faced with same situation as you are facing now.
The last endoscopy result you had is just like a replica of mine.
What is the way to go.
Navinavi
Post by Navinavi »
Hi Helico_expert,
My last stool test was negative. Still have symptoms through, not sure if heartburn, maybe it is diet related.
Thanks for your guidance.
@kayce008 I replied on your PM
