Does this therapy work??
cyprian zimunya
Post by cyprian zimunya »
I want to ask that does this therapy more effective to eradicate h pylori.. amox ig three times a day ,bismuth 120mg three times a day , metronidazole 200mg three times a day and esomeprazole 40mg 2 times a day... my main voncern is on metronidazole i have used it before so it might not work ..furazolidone is not widely spread in my country so i might not able to get it ..so is there other antibiotic that i can use instead of metronidazole or i can just use metronidazole since i heard you saying that metronidazole resistance can be overcomed when using another strong antibiotic
Re: Does this therapy work??
High dose PPI + High dose Amox + Bismuth may already give you a cure rate of 80%.
Metronidazole resistance has been shown to be able to be overcome when used with Tetracycline. Since The H. pylori will not become resistant to Amox and Bismuth, I think you can give this quadruple (PPI + Amox + Bismuth + Metro) a try.
If it failed, you can always repeat PPI + Amox + Bismuth + one other antibiotic.
cyprian zimunya
Ok i will take your recommendation thanks. What about if it failed what other antibiotic should i add there?...is tetracycline and amox the same or is it possible to add tetracycline there or i should not add it ,it will reduce the effectiveness of amox
very good question. In theory, Amox and Tetracycline should counter each other. But in practical they dont. I am not sure why.
So, Yes, tetracycline can be your next choice if your current therapy failed.
cyprian zimunya
Ok thanks so i can include tetracycline in my therapy if it failed ..so it will be amox,bismuth, tetracycline and ppi
Yes. But hopefully your PBAM will work and you dont have to try PBAT.
cyprian zimunya
Lets hope it will work i will talk to my doctor about. Is it possible to increase omeprazole dosage to 40mg twice a day
yup. you can do 40mg twice a day.
cyprian zimunya
I finished my antiniotics for h pylori four weeks ago ,since then i was on ppi but there are no changes yet ,should i start worrying or give my stomach time to heal . I have chronic gastritis and h pylori
You can gradually stop your PPI.
switch to one tablet a day or a tablet every two days.
