Symptoms: One month post-eradication: How to promote healing?
eliuri
Post by eliuri »
Hi:
I completed triple-therapy for H.Pylori about a month ago. Was just notified by Dr's office that breath test was negative. I do however still have some upper GI pain. Though somewhat less than before treatment The original Dx was: "Chronic, active gastritis" via endoscopy. (no ulcers)
Questions:
1) What is the usual time frame for gastritis symptoms to resolve post-treatment?
Is it unusual to still have pain one month after completion of treatment?
2) Are there things I can do meanwhile to promote healing of the digestive tract?
For example:
Would another 2-week course of a PPI give it a better chance of healing? Or is that just symptomatic relief?
I did notice that during the 2 week period I was on antibiotics/PPI the symptoms had disappeared and then re-appeared after the therapy. Though less so. I was afraid this meant the treatment had failed, but apparently I'm now negative for H.Pylori. So perhaps symptom relief then was due to PPI
Re: Symptoms: One month post-eradication: How to promote healing?
The recovery is subjective. It depends on the severity of the damage done by H. pylori. Therefore, some PPI may help. There is no harm taking PPI, so if you feel better taking PPI, do take some.
Some people also take some probiotics or alternative medicine to aid the recovery. As long as H. pylori is definitely gone, then there is a chance of true recovery.
Northp
Post by Northp »
Hi
I found the PPIs made me so tired. It might be that you need acid to digest your foods so I was not getting nutrients while on the PPIs. I decided to discontinue them (Also Acid Rebound is very painful, happens when you stop using PPIs). However you should also be aware of trigger foods. For me it was dairy, spicy and fried foods that caused my gastritis to be so painful. Try to avoid them while healing.
I've gone to a naturopath for alternative routes to healing my stomach. He suggested L-Glutamine, plant digestive enzymes and some probiotics. Patience, positive thinking, avoiding trigger foods along with the natural remedies, I am finally feeling relief after 2 months post treatment.
I have found this forum to be helpful as I realized I was not alone with post-treatment symptoms.
Good luck to you.
Naturopath is good idea to help recovery.
However, if acid reflux is making you pain, you should continue PPI. PPI can prevent your throat getting damage and your teeth being corroded.
eliuri
Post by eliuri »
"Therefore, some PPI may help. There is no harm taking PPI, so if you feel better taking PPI, do take some."
It might help. BUT my question is whether a PPI would actually promote healing by giving stomach "a break" from all that acid--thereby allowing it to recover. Or would it be just relief from annoying symptoms. As of now, the symptoms arent bad enough to warrant taking a medicine.
Oddly, the reflux symptoms I had prior to the H.Pylori treatment are now very much subsided. Mostly gastric pain now. So wondering if PPI might still be helpful in the healing process for gastritis I do continue with the probiotics which I had used during the treatment period.
I have come across some medical article which suggests capsaicin--found in hot chili peppers-- might actually help gastritis, but here again I'm not sure if merely symptomatic help or actually help the healing process. Things like that--I'd be interested to learn about
I am not sure what are the factors that cause your pain.
But if your pain is because the acid burning your stomach, then yes, PPI can relieve that pain.
The idea is that H. pylori damage the cells producing mucous. As the mucous gets thinner and thinner, eventually the acid is going to digest your own stomach.
When H. pylori is eradicated, the mucous producing cells will gradually come back and your mucous will go back to normal ("finger cross"), then your stomach is once again protected from acid.
So in short, yes, PPI can buy time for your stomach to recover.
We have not done any study to actually measure diet and stomach recovery. But from our observation, patients generally go back to their normal diet, any diet, and eventually most of the patients do feel better.
You can try whatever natural herbs or therapy you want, but dont over doing it. Over doing anything good will eventually turn bad.
