Advice needed
Re: Advice needed
There is no guideline to post treatment. However, in the forum, some members have good recovery with probiotics. I personally like mint tea and honey. Perhaps you can give these natural product a try.
Kingdawson
Re: Advice needed
Post by Kingdawson »
Hi guys need some advice.
So finished triple therapy last Sunday. Everything was pretty good except one bout of diahrrea on the second day.
Anyway a few days after treatment I am getting diahrea again (quite watery which wasn't the case the one time I had it during treatment). I've had it for 2 days now. Other than Pro biotics is there anything I can do?
Re: Advice needed
the watery diarrhea should gradually reduce. depending on how severe it is, if you think there is a need to seek medical advise, you should go see your doctor and check for potential C. diff complication.
Kingdawson
Re: Advice needed
Update
So things have settled down. Still get bouts of diahrrea the day after drinking alcahol so I guess that's a no no for now. Taking the VSL Pro biotics which is super strength live bacteria so hopefully that helps.
The positives are my stomach is not as noisy no more and I'm not getting hunger pangs which I did prior to taking the anti biotics.
I did a stool test prior to taking the anti biotics to check the amount of good bacteria and I was very low on some of the main ones ...and that was before taking antibiotics so god knows what if is now. Just got to take it easy for a while I guess.
Re: Advice needed
good job. remember to get a follow up breath test one month after treatment.
Kingdawson
Re: Advice needed
For some reason I randomly remembered this thread and wanted to post a quick update that I eventually tested negative for Hpylori.
Re: Advice needed
hooray!!
congratulation! we need more members like you to come back with good news.
