Stool sample and testing
3rdy
Post by 3rdy »
Hi
How many times do they test your stool sample for h pylori?
Reason I'm asking is that I started suffering from constipation then stomach pains after eating
Went to dr....provided stool sample and after a few days nurse phoned to say I h pylori and prescribed me the triple therapy
Then the constipation turned to loose stool so back to dr...Sent me for colonoscopy which turned out normal...back to different Dr I explained about being diagnosed with h pylori and could i still have it?
And she said....your second sample was clear???
Do they test the sample more than once?
Re: Stool sample and testing
yes. you need to find out if your triple therapy actually work. Usually you require to wait for a month after stopping all medicine. Then you can proceed with the stool antigen test again.
3rdy
Post by 3rdy »
Ok, thank you
Got a bit confused there..both the nurse and 1 doctor never mentioned anything about the second test
Will go back and see about a retest :)
