Triple therapy and PANIC
Steven
Re: Triple therapy and PANIC
Post by Steven »
Helico_expert wrote: Tue Sep 11, 2018 9:21 pm you should stop PPI for at least 2 weeks before endoscopy. try talk to your doctor about switching to ranitidine. you can have ranitidine until the night before endoscopy.
Thanks for your reply.
Just got off phone to clinic and my appointment is for Saturday so too late to stop the PPI’s unfortunately. I’ll tell the clinic this too otherwise I’ll end up with a false negative. At least we’ll know what condition the stomach is in afterwards. I’ll retest for HP in a few weeks time and in the meantime will talk to him about switching.
Appreciated.
helico_highBP
Post by helico_highBP »
Hi All ,
Please advice
Emergency Instances : -
H Pylori Detected :
After 6 visits with Doctor I got chance to do breath test and got detected positive for H Pylori - which I was happy because I though at least they found something wrong and something they can work on.
H Pylori Treatment :
Now my treatment is complete where I got 3000 mg of Amox + Clarithromycin + Omeprazole(20mg*2) for 14 days .
Post H Pylori Treatment :
Feeling much better compare to past month , started driving , playing tennis a little bit but since yesterday I started getting more stomach acidity , bloating and cold sweat sometimes.. I also started experiencing Heartbits / fluttering kind of sensations but Apple watch still shows heart rate between 75 - 97 bpm.
Thank You
thanks for your detail story. I think at least you manage to finish the treatment with ease. you need to follow the protocol and get a follow up breath test after a month without medication. then you will know if you still have H. pylori in you. It is important to find out if H. pylori is eradicated. Only then you'll be truly recovered. otherwise you'll just be waiting for something that will never happen.
some people does take longer time to recover. please be patience and update us again after the follow up breath test.
Steven
Post by Steven »
Well after nearly having a full on panic attack prior to endoscopic exam, I calmed down and had the exam. It was no trouble at all after all the worry.
They discovered an esophagus hernia. No ulcers, no gastritis, no inflammation to esophagus. I think 6 weeks of PPI’s has helped. 6 biopsies taken. They also said no HP but I only came off the PPI’s 3 days ago so a retest still required.
Still to see an ENT next week for nasal endoscopy regarding the hoarse voice (due to constant swallowing) and globus sensation - probable stress rather than GERD related is my guess.
I’ve swapped the coffee for mint tea, eating more fruit, having some probiotics, drastically reduced my chocolate intake. Also drinking a protein formula I used to use at the gym to try and get the weight back on. It also includes all your vitamins and trace elements so won’t do any harm.
It’s a diagnosis which means I will have to make adjustments with diet and lifestyle but I can live with that.
sounds like your symptoms are improving. that's good news. remember to update us your breath test result.
schism
Post by schism »
Steven wrote: Sun Sep 16, 2018 2:23 am Well after nearly having a full on panic attack prior to endoscopic exam, I calmed down and had the exam. It was no trouble at all after all the worry.
I’m in the same boat you were — about to have panic attack before my EGD. I’m just really afraid of the aenesthsia drugs. They said they’ll use propofol and it just freaks me the hell out. I hate losing control. Did they use propofol on you?
Steven
Post by Steven »
schism wrote: Tue Sep 18, 2018 10:15 am
How did you get on?
As a fellow panic sufferer we both know that the fear of something is worse than the actual reality. I was the same when I needed plate and screws in my ankle, I refused to be put under and went for the the nerve block.
They gave me Fentanyl and Midazolam. After that they could have put a fire hose down the throat and I wouldn’t have cared :-). I didn’t feel loss of control as you mentioned just calmness. Short lasting, no more than an hour. I wouldn’t be nearly as nervous if I need a further one. Also had a nasal endoscopy yesterday which was simple. No spray or sedatives needed there.
Hope it went well for you?
schism
Post by schism »
It went well for me as well. They used the propofol which knocked me out cold. He gave me just a couple drips at first which made anxiety vanish and room started to shift. Then few seconds later I was out. Woke up feeling pretty good 15 min later. I’ve been a bit off/dizzy next day and woke up with a headache, but seems to be dissipating.
Steven
Post by Steven »
schism wrote: Fri Sep 21, 2018 11:21 am It went well for me as well. They used the propofol which knocked me out cold. He gave me just a couple drips at first which made anxiety vanish and room started to shift. Then few seconds later I was out. Woke up feeling pretty good 15 min later. I’ve been a bit off/dizzy next day and woke up with a headache, but seems to be dissipating.
Pleased for you :-). What did the doctor say?
providoregifts
Post by providoregifts »
Hi everyone, i am new on this.
