Negative or positive h pylori test
Re: Negative or positive h pylori test
You have borderline positive, which is hard to believe. We would ask the patient to repeat the test in a week time. If breath test cannot give conclusive diagnosis, then you will need to ask for stool test.
Fabio Cesar
Post by Fabio Cesar »
Boderline positive ? So it means I still have h pylori right?
borderline means the result is un-determined. It's neither positive nor negative. You just have to do the test again a month or two later.
Roland
Post by Roland »
Breath and stool tests, which is more reliable?
They are both reliable. However, the accuracy is dependent on who is running the test. if you buy the test from websites and do it yourself, you may not be experienced enough to give accurate result.
Roland
Post by Roland »
What is your take on negative stool and positive breath test.
What does this imply? Which one is most accurate?
Roland
Post by Roland »
In my case doctor ignored my breath test which was positive and went with stool test which was negative. Does that mean Iam actually negative?
I'll look at the raw data of both your breath and stool tests. How positive and negative are both tests?
Roland
Post by Roland »
Hpylori- urea breath test
Result 398
Flag: H
Unit: CPM
Range: 0-40
if the cut off is 40 and your reading is 398, it looks high enough to be true positive.
perhaps you need to wait another month to repeat the breath test just for sure.
