Triple treatment side effects - at what point should you tell doctor?
hpylorisymp
Post by hpylorisymp »
Hi all,
I have been feeling poorly for about a month, and I believe I was infected with H Pylori shortly over a month ago (but not sure how fast it takes for symptoms to show up). I was gassy, bloated, and had what I believe was abdominal spasms multiple times a day - they were painless. I had a few stomach cramps but they were mild, and I did not experience heart burn.
My blood test showed I was H Pylori positive - stool and ultrasound showed nothing. I started a triple treatment about 60 hours ago (2 and a half days ago). I am taking:
1. 500mg Clarithromycin, twice daily (1000mg/day)
2. 1000mg Amoxicillin, twice daily (2000mg/day)
3. 20mg Rabeprazole, twice daily (40mg/day)
Starting from about 24h in, I started experiencing side effects. I woke up in the middle of the night feeling like I was nauseous and had a bad taste in my mouth. The next morning, I had diarrhea, and this has continued to the third day. I have also experienced nausea and dizziness during the day time yesterday. For the past 48h, I have also had a dry mouth. Today, I started feeling stomach pains that feel the same intensity as moderate period cramps. Yesterday, I also had a right lower leg ache, but not sure if that is related.
I am not sure at what point the symptoms are severe enough that I need to contact my physician who prescribed them. I am currently feeling all these symptoms on and off, none have been constant since I started getting them. I have 8 doses left (4 days) of the triple treatment. Do these all sound normal, and fine? Did you experience any of the same? I am worried that because I have so many side effects, this indicates that my body is not reacting well to it. In fact, I feel more discomfort now than I did before the infection was treated, although I would rate it a 3/10 on the pain scale.
Re: Triple treatment side effects - at what point should you tell doctor?
diarrhea, nausea, metallic taste in the mouth, and fatigue are all common side effects of antibiotics. You just take it easy, plenty of rest, lots of water and fruits. try distract yourself by doing something that you like. eg TV, music, reading, exercise. If your side effect is so bad that you cannot do any of the above, you feel like going to hospital, then you have to stop the antibiotics and discuss with your doctor.
hpylorisymp
Thank you for your reply! Feeling less worried about this now. :D
TomHiddleston
Post by TomHiddleston »
It's always best to err on the side of caution when it comes to medication side effects, especially if they are causing you discomfort. I would recommend contacting your physician as soon as possible to discuss the symptoms you are experiencing. They will be able to assess whether these side effects are within the normal range or if there may be a need to adjust your treatment plantime calculator.
bevis0405
Post by bevis0405 »
It's important to consult with your doctor if you have any concerns or experience severe side effects. They can assess your situation and provide appropriate advice. Run 3 Unblocked
Noahenet
Post by Noahenet »
It’s common to experience side effects when starting treatment for H. pylori, including nausea, diarrhea, and abdominal discomfort. However, if your symptoms worsen or become severe, such as intense pain or persistent vomiting,Snow Road you need to contact your physician for advice.
