Hey guys, I wanted to share my experience thus far with this nasty bug.
My stomach problems began last august while I was undergoing a course of doxycycline for lyme disease. It began with an empty/uneasy feeling in my stomach that was with me 90% of the day. I had thought that it was a side effect of the anitbiotics at the time and I kind of lived with it for a couple of months (silly me). Then last December, the stomach problems shifted gears. I had started getting some nasty bloating and heartburn, plus some peripheral neuropathy. I found some relief by using digestive enzymes each meal, but eventually I finally went back to the doctor and tested positive for H Pylori.
So I went through the standard first-line treatment of amox, clarithro, plus pantoprazole. The antibiotics were pretty nasty, but I finished the whole course. For the 2 weeks after the antibiotics and while I was still on the ppi, I felt really terrible. Food was taking way too long to leave my stomach, and I was feeling weak and dizzy. It was quite painful. I finally cut out the ppi and started drinking an apple cider vinegar/water cocktail before each meal, which made me feel 100 times better. I was also taking probiotics, and started drinking kombucha daily around that same time. I had almost felt "healthy" at one point last spring, but I decided to cut back on the kombucha and my stomach problems came back. It was very discouraging.
At this point, most people would say that I should have gone back to the doctor for a retest and more antibiotics, but I was worried about what a follow-up course of antibiotics would be like after having struggled through the initial course. I should mention that I have a genetic disorder which affects my cortisol production, as well as an aortic dissection which was grafted together when I was 21. The first course of antibiotics had played havoc with my blood pressure, and I am sure the next course would have been worse. I started looking into natural alternatives.
I started taking mastic gum about 2 1/2 months ago, as it seemed like the alternative treatment of choice from my research. I started with 500mg twice a day for a week, then upped it to 1g twice a day. The mastic gave me a lot of relief for symptoms that weren't related to my stomach. I had experienced die-off symptoms the first 2 weeks of it, followed by a large increase in my energy levels and motivation. After the first month, I decided to add another treatment, and started taking broccoli sprout supplements, for the sulforophane. This gave me another round of detox, followed by more relief from my symptoms, but after 3 weeks my stomach symptoms were still there, and I felt like it would not be enough. More research led me to Colostrum for its ability to unbind the H Pylori from the fat cells in the stomach lining (source: http://jid.oxfordjournals.org/content/1 ... 5.full.pdf). The Colostrum gave me an intense detox for the first week of taking it, but afterwards I felt like a new man. That empty/uneasy feeling, which had always been there even through the antibiotic course, is finally leaving me. My energy levels are higher now than I ever remember since my heart surgery, my muscles feel much stronger and less achy, and my digestion has improved greatly. I am still having some symptoms and am not out of the woods yet, but I feel better by the day and I am optimistic. I will continue on with these 3 supplements for another month or so, depending on how I feel, then I will ween myself off and see the doctor for a retest. Though I will probably consider taking a maintenance dose of Colostrum for the rest of my life. The stuff makes me feel amazing.
Long story short, I highly recommend Colostrum as a supplement to any other H Pylori treatment. I can't speak about the safety of it when mixed with pharmaceuticals, so check with your doctor.
My experience with H Pylori and alternative treatments
Re: My experience with H Pylori and alternative treatments
I should also say that I don't recommend foregoing the antibiotics to begin with. I had only pursued alternative methods because of the initial antibiotic failure and my complicated health history.
thanks for sharing your valuable experience and glad that you felt better with the alternative treatment.
However, I would still suggest you to get a check up to find out if you still have h. pylori. there is a small chance that your symptoms are not related to H. pylori.
helico4eva
Helico_expert wrote:thanks for sharing your valuable experience and glad that you felt better with the alternative treatment.
i feel some of my heartburn and bloating symptoms are like you
for heartburn i reduced Carbs instake a lot..basically eating mixed greens and protein only helps as starches/ carbs/ sugars ferment when digestion is a bit weakened by this bug causing acid reflux
kombucha and plain kefir helps along with probiotics
herrybraun
- Contact:
Thanks for sharing your experience with H Pylori and alternative treatments, I always appreciate such a useful and unique health information topics.
