Need advice for my treatment regime with furazolidone
l126t
Post by l126t »
My treatment course with furazolidone
I'm a 30-y-o chinese male Patient .
Erythematous exudative gastritis
I want your advice for my treatment regime:
Pariet (PPI) 10mg twice a day before meal
CBS (220mg bi) twice a day before meal
Amoxycillin 1000mg BID after meal
furazolidone 100mg BID after meal
I'm worry about heavy metal(cbs). Should i reduce or remove cbs.
Now my 13c test dob=12.3
2009 I 'v taken lansoprazole 30mgbd ,clarithromycin 500 mg bd/amoxicillin 500 mg bd,7days
but that's not work for me.
and my colonoscopy Examination result is :
colonoscope arrival ileocecal part. the surface of the ileocecal valve is edematous, scattered erosion is seen, take two biopsies . The rest involved colorectal part is normal, which mucosa is smooth, vascular texture is clear.
Pathological examination: 0.1 cm two biopsies ,glands of mucous are Regular, interstitial fibrous tissue proliferate, a large number of inflammatory cell infiltrate, lymphoid follicles are produced.
Re: Need advice for my treatment regime with furazolidone
We call this the PBAF treatment and we have a cure rate of 73%. In our treatment, we uses even higher dose of Bismuth, 240 mg 4 times a day. I wouldnt worry too much about Bismuth. Whereas, Furazolidone may give you some bad side effects. Nevertheless, we also give higher dose of furazolidone to our patients.
please refer to our publication below.
Full article
http://onlinelibrary.wiley.com/doi/10.1 ... 12089/full
supporting document (treatment dosage)
l126t
Post by l126t »
what do you think of the colonoscopy report ?
Is it related to Helicobacter pylori?
I dont think H. pylori is related to your colon problem. H. pylori is very specific to stomach only. Nevertheless, very little is known if the "toxin" it produces has any effect outside the stomach.
Sorry, cannot comment much on the colonoscopy report. But, it seems quite normal. At least there is no ulcer or bleeding or any deformation. Let's wait more info from the biopsies.
alicebobby
Post by alicebobby »
I don't believe that your intestinal issue is connected to H. pylori. H. pylori is unique to the stomach. However, it's unclear if the "toxin" it creates has any effects outside of the stomach.  tunnel rush
