Post Pylera Treatments .. Acid Blockers ..Probiotics ?
Fredd77
Post by Fredd77 »
I would like to know what is recommend to take after finishing PYLERA .. Should i keep taking omeprazole once a day or 2 and for how long ? :?: :?: :D :ugeek:
Re: Post Pylera Treatments .. Acid Blockers ..Probiotics ?
There is no guideline to what to take after finishing H. pylori treatment. There is no need to continue omeprazole unless you were diagnosed with ulcer, you'll need to continue PPI for a month until it's heal. Or, for patients with reflux, they have to continue PPI until they feel better.
Fredd77
Post by Fredd77 »
(I finished my 10 day pylera treatment) I feel like the h Pylori was eradicated i feel alot better overall but im still having acid reflux .. should i keep taking 1 omeprazole daily until the acid reflux leaves and is it okay to take it for more than month amount of time and how long does the acid reflux usualy last if the pylera successful ... i have to see my doctor in August
I am glad to hear you feeling better. However, you have to confirm the eradication with breath test.
Talk to your GP. He would prescribe you necessary PPI and advise you when to stop for breath test.
Fredd77
Post by Fredd77 »
Alright i went to my G.I doctor and she told me my stool test says im Negative for Hpylori :D :D :D but im still having acid reflux :? what should i do and how long does it usually take for your acid reflux to go away ( I dont have an ulcer )
newhpyloridiag
Post by newhpyloridiag »
Ulcer will take time to heal. At-least few months. Did you stop PPI for at-least 1 week prior to the stool test? If NO, then that can be a false negative. Before the follow-up test (either Breath or Stool), the PPI has to be stopped for a period of at-least 1 week (better if it is 2 weeks)
Since you have an ulcer you are better of taking the PPI for atleast 3 months to 6 months. Talk to your Doctor about it.
Whether to take once or twice depends on how bad the reflux is. Usually one should be good enough.
Since you have an ulcer watch what you eat, so that you wouldn't irritate it.
Take some pro-biotics (if you are not allergic to dairy) like yogurt, kiefer. Or you can also take pro-biotic pills.
Finally stool test is good but Breath Test is the best.
Fredd77
Post by Fredd77 »
yes i think i stopped taking my omeprazole pills about exactly 17 days before the stool test ,can i take 2 omeprazole pills a day ? is there natural supplemant that can coat the throat ?
You can if you feel that it helps. by the way, it doesnt coat your throat. It blocks acid. PPI is afterall very safe drug. Nevertheless, your family doctor should know you better. It's always good to get his opinion in your case.
aaalvarez
Post by aaalvarez »
Before the Palera treatment my stool was ok with the color, since I stared w the Pylera turned black, already fineshed the treatment 4 days ago, is it normal? How long takes to my stool color comes back to normal? Please, can somebody answer my question?
I have answered this in other post. I would wait a few more days before seeing a doctor about it.
