a new symptom for 2 days
dioxnet
Post by dioxnet »
a new symptom for 2 days, drink hot tea and 2 seconds left hurts me, it seems as if in the middle of the stomach, I tried drinking only hot water ... and the same to each drink a pain. very mild .. and removed immediately .. it's like to pass water, make a nuisance with cold water does not pass
español
un nuevo síntoma desde hace 2 días, bebo te caliente y a los 2 segundos, me duele lado izquierdo, parece como si fuera en el centro del estómago, he probado bebiendo agua caliente solo... y lo mismo a cada trago, un dolor... muy leve y que se quita inmediatamente.. es como si al pasar el agua, hiciera una molestia, con agua fria no pasa
Re: a new symptom for 2 days
try not to drink your water too hot. You'll burn your throat and esophagus. Have you spoken to any gastroenterologist?
dioxnet
Post by dioxnet »
talk in December, told me that my problem was my stress and my eating, or possible h. hiatus, I change my habits but still the same, that if since taking
probiotic, only contine L.reuteri, burning some point, but nothing and sunburn
on new symptom, not good if you are new symptom, it is since I encouraged drinking green tea, for months without wearing anything hot liquid.
been researching this last, and could be the hot liquid, in contact with stomach acid, creating more acidic reacts
