What is LAX LES?
syedkhalid
What is LAX LES?
Doctor mentioned in my Endoscopy report that i have LAX LES. What is LAX LES and i also like to know about hiatal Hernia. Do Hiatal Hernia have connection with LAX lES?
Re: What is LAX LES?
LES is referred to lower esophageal sphincter. LAX is referred to "loose".
So a LAX LES causes hiatal hernia where the stomach is partially migrate into the chest.
syedkhalid
Symptoms of Hiatal Hernia?
for more information, try this websiteSymptoms of hiatus hernia
Often, a hiatus hernia won't cause any symptoms. However, it may cause a feeling of warmth or burning in your chest, which is called heartburn. This happens when the contents of your stomach, which are acidic, reflux (flow backwards) into your oesophagus. If you have heartburn symptoms that go on for a long time or are severe, this is called gastro-oesophageal reflux disease (GORD).Other symptoms include:
severe pain or discomfort in your chest
belching
hiccups
gurgling noises in your chest.
Some people develop a croaky voice or asthma symptoms.
Your symptoms may start or get worse after eating, while lying down or when you bend forward.
http://www.bupa.com.au/health-and-welln ... a#symptoms
john wilson
- Contact:
In “LAX LES” the LES is a lower esophageal sphincter which is like a one way valve which prevent the gastric juices from flowing back during digestion as the stomach add acid juices, as the stomach’s lining is capable of handling these strong acids and so as the esophagus.
Thus the incompetency of esophagus results in GERD known as a gastrophageal reflux disease which has a common symptoms like heartburn.
I suggest to avoid spicy food, nicotine, tomato sauce, peppermint and alcohol.
http://herpeseliminator.com/
syedkhalid
I don't have heart burn at all. Even if i run or do hard exercises. But i have some kind of weird sound in chest. Every early morning i vomit. i see some spicy white fluid coming out from my mouth. Its smells alike the food which i had in my last dinner. i have mild stomach burns
Katrine Chan
Good Day to you all!
Hope to share and help with helpful information, that i found on this website http://hernia-treatment.net/symptoms-re ... -treatment. I was suprised by the amount of information that given there.
tmogkawaii
- Contact:
I was the one who interests me about them.
PaulMcKein
Hello to everyone! I was at the conference dedicated to hernia treatment so the doctors and lectures discussed the issues and ways how to get rid of pain. So I found some simillar information below this link http://hernia-treatment.net/repair-hiat ... techniques.
AndrewLRose
- Contact:
Helico_expert wrote:LES is referred to lower esophageal sphincter. LAX is referred to "loose".
Do you mean that LAX LES is the cause of hiatal hernia? This is the 1st time I heard about the term of LAX LES. So I am clear now and maybe will have searches about this topic.
http://alphafuelxtsupplement.com/
