any connection of Hp with Barrets Syndrone?
samsgut
Post by samsgut »
Hi I have recently had an endoscopy which showed Barrets. I had previously had a breath test for helio but it came back negative ( reading of 49). Despite major dietry changes - no wheat, dairy, which caused my symptoms of pain at end of esophagus in the first -place,I'm still getting abdonminal pain. Dr now suggesting reading was close enough to positive as I had had some herbal ixtures in previous week. Now on 7 day hp treatment but want to know if the Barrets could have been caused by the hp as ulcers are?
Re: any connection of Hp with Barrets Syndrone?
From my understanding, there is little to no association between HP and Barrett's esophagus. In fact, some recent studies even suggest a inverse relationship between HP and Barrett's esophagus. Meaning, HP protects you from getting Barrett's esophagus.
http://www.ncbi.nlm.nih.gov/pubmed/19174811
Anyway, I think the correlation is still not strong enough. More studies are needed. Perhaps you should go for a second follow up breath test?
samsgut
Post by samsgut »
Thanks for the reply. Yes the research was interesting. Feeling so much better on the antibiotics and will get another test done a week after I finish them.
you'll need at least 3 weeks without antibiotics and PPI before any test to check for H. pylori infection.
samsgut
Post by samsgut »
ok thanks for that, I will wait the three weeks.
