High-dose dual regimen
Adam
Post by Adam »
High-dose dual - PPI + Amoxicillin. Is the cure rate high? Is this a good regimen? If it is, which PPI, do you recommend and why?
Re: High-dose dual regimen
High dose PPI and High dose Amoxicillin can give good cure rate.
You can try rabeprazole or the new vonoprazan.
