any test that can be done by taking antibiotics or omeprazole
and do not leave altered stool control?, analytical blood?
or any?
thanks
Test...... omeprazole or antibiotics
Re: Test...... omeprazole or antibiotics
unfortunately no. while taking antibiotics and PPI, the bacterial load reduces. So you may get false negative results from stool and breath test.
However, any positive results from stool/breath test would be true positives.
Blood test is not affected by the antibiotics and PPI. However, blood test only tells you the history of infection. It cannot tell you your current infection status. Nevertheless, blood test only has false positives. Any negative result from blood test is a true negative.
Gracias, thanks
