Most Accurate Alternative to Breath Test/Endoscopy
Blood tests (for antibody) are used to screen for H.pylori. They remain positive for many months after treatment so can only be used as the initial test. Urine antibody is a "pregnanacy style" urine test. Accuracy is slightly less than blood tests. A negative blood test is good evidence that Hp is NOT present. Use it to exclude the diagnosis (but no test is 100% perfect remember).
healing3
Post by healing3 »
I'm expecting that my GP will want to do a test for HP. What is the most accurate alternative to breath and endoscopy testing?
Re: Most Accurate Alternative to Breath Test/Endoscopy
Blood and stool tests are equally good. Blood test tells you history of infection, not your current infection status. if you have never taken h. pylori treatment, you can assume that you are still infected and do blood test to confirm.
Yoltookane
Post by Yoltookane »
You find out how to fix it yet?
Return to “Antibody type Tests (blood or urine antibody)”
