Hi guys, I’ll try to be short but I’m having troubles to detect this bacteria in multiple tests.
My digestion is wrecked, but it all started 6-7 years ago when I started to get bad gastritis, lots of burping and reflux, specially with spicy food, general indigestion, then I started to get constipated and bloated.
Atm I thought it was because I was eating so bad, but then I changed my nutrition and symptoms persisted for a long time, until the last 1-2 years, those symptoms have almost dissaparead but I do get them occasionally but now I’m just constipated and I have no digestion whatsoever, I see food in my toilet.
My nutrition has been EXCELLENT this past few years, that’s how I’ve been treating whatever I have because I never knew what I had, then I proceeded to investigate and I did several lab exams.
I did an endoscopy showing chronic active mild gastritis (first red flag for me) pylori negative on this one
Colonoscopy, everything good.
GI MAP showed h.pylori HIGH with 1.9e3 and reference is below 1.0e3 (second red flag) Candida high and opportunistic bacteria high (IMO caused by long term hypochloridia)
Now this is the weird part. I’ve done 2 Antigen stool test, and 1 blood test. I’ve had 1 stool test being positive, other one being negative and blood negative. So overall I’ve gotten 2 positive tests (GI MAP and AG stool test)
My theory is that pylori is still present in my system but in a very low quantity but enough to be causing my hypochloridia (After natural treatment I was taking up to 7 HCL Pills with no improvement) and I think hypochloridia is what’s causing my body to not digest food all this years. So my fear is that how come I’ll know when pylori is not anymore in my system after treatment since I’m getting lots of false negatives?
My mistake was letting this bacteria stay so long in my body and “treating it” with nutrition for years to a level where not even tests can catch it 99% of the time. I’m thinking to have treatment and do a GI MAP since that’s IMO the most sensible exam out there.
It’s important to say that before all this stool tests and blood tests, in the same month I was doing Hulda Clark parasite cleanse (finished it) taking wormwood, cloves and green black walnut hull.
Any advice?
My Pylori is HARD to detect?
Re: My Pylori is HARD to detect?
confusing information.
Active chronic gastritis usually mean presence of H. pylori
Blood test is usually very accurate in detecting history of H. pylori exposure regardless of having H. pylori now.
GI Map is doing DNA testing and may have false positive.
GI Map can be used as a reference but it is never the recommended test for H. pylori.
At least your endoscopy did not show any abnormalities.
Perhaps you can get your doctor to review the histology slide again.
The negative blood test is leading me to believe that you are free of H. pylori.
Things tl
Blood test was done after completing dr holds Clark antiparasite program so I think that’s why i was getting false negatives
What I fear the most is that I’ve been having pylori symptoms for 6,7+ years and I’m positive I have low stomach acid plus I’ve gotten several tests with a positive result and a history of anemia/cancer in my family
Is it a possibility that natural abx including wormwood, cloves, garlic etc made me have so many false negatives?
———Helico_expert wrote: Sat May 22, 2021 11:20 am confusing information.
This was before any natural treatment (including antimicrobials antifungicids) so my symptom were more present.
I’ve had pylori from 6-7+ years and being treating it with garlic, onion, natural antimicrobials and a clean diet but never had a pylori abx treatment that’s why I’m suggesting I do have pylori but very low, I don’t have any other explanation for my gastritis and hypochloridia
My endoscopy showed some parts paleness and chronic mild gastritis plus I got the symptoms from a long long time ago and I never treated them or whatsoever with abx. I’m really scared I’m developing some kind of cancer since I literally don’t have any stomach acid, I don’t feel I have I just feel food sitting in my stomach for long times.
Is it possible that thanks to dietary changes, natural antimicrobials, lifestyle changes basically, pylori has been on remission but not erradicated?
Now that I remember, during the endoscopy I was using a PPI for a whole week before, and during all my tests I was using antimicrobials and bismuth, I think that’s why I’m getting all this false negative but got a positive
blood test is not affected by previous treatment. If you had H. pylori before, you will get a positive antibody test.
Bismuth and potential antimicrobial herbs may contribute to false negative result in histology and breath/stool test.
I think since your endoscopy is normal, apart from some mild gastritis, you can take it easy. Try some H2 blockers or probiotics to help relief the symptoms. Perhaps retest yourself again for H. pylori 1 or 2 months later. H2 blockers and probiotics will not affect the stool/breath test.
The problem is that I have hypochloridia, SIBO and candida IMO caused by the hypochloridia, which I suspect is caused by long term hylicobacter pylori. will H2 blockers will cause further damage since I already have low stomach acid by pylori? I cant digest well most of the proteins..Helico_expert wrote: Sun May 23, 2021 10:17 am blood test is not affected by previous treatment. If you had H. pylori before, you will get a positive antibody test.
Yea, H. pylori can cause inflammation which ultimately leads to lowering acid.
It's interesting how you asked about the damage caused by H2 blocker. Because usually it is the acid is causing the damage. When you have too much acid, you get reflux. or when your mucus layer is depleted due to inflammation, you get ulcer from acid.
So you are actually better without acid. But the flip side is that your food may not be properly "sterilised" and there may be other microbes growing in the stomach that can lead to other problem.
Nevertheless, H2 blocker is a weak acid blocker. It doesnt have a long active life in the body. So I wouldnt worry too much about long term "damage".
