Stool test
Posted: Mon May 17, 2021 11:05 pm
by Clyde
After 2 failed triple therapies I've tried bismuth monotherapy with Rabeprazole with 14 days duration.
Bismuth subcitrate 240 mg qid
Rabeprazole 20 mg bid
3 weeks after discontinuing medications I did a stool test and the test result was negative.
Should I wait for more than 3 weeks or this time is enough to get reliable result?
Re: Stool test
Posted: Tue May 18, 2021 9:24 am
yup. this dual therapy has a cure rate of about 20%. and you may be the lucky one.
Re: Stool test
Posted: Wed May 19, 2021 12:57 am
by Clyde
Helico_expert wrote: Tue May 18, 2021 9:24 am
Some labs note that Bismuth compounds should not be taken 2 weeks prior to the test, while others 4 weeks prior to the test. Which one is correct?
Re: Stool test
Posted: Wed May 19, 2021 9:31 am
2 weeks is good enough. But in general, the longer you wait, the better chance for more accurate result.
It all depends on the bacteria load. If there is not enough bacteria, then you'll get a false negative result. So antibiotics, PPI, bismuth, some herbs, may reduce the H. pylori load. So try avoid them before the test.
Re: Stool test
Posted: Wed May 19, 2021 5:43 pm
by Clyde
Helico_expert wrote: Wed May 19, 2021 9:31 am
So, I took bee products and some essential oils a few days before the test. Should I discontinue these products for 2 weeks before the retest? Would that be enough to get accurate result?
Re: Stool test
Posted: Thu May 20, 2021 9:12 am
We did some experiment on essential oil recently and found some anti-H. pylori effect. So it's probably a good idea to stop essential oil for 2 weeks before the testing.
Re: Stool test
Posted: Sun May 30, 2021 10:57 pm
by Clyde
Helico_expert wrote: Thu May 20, 2021 9:12 am
I'm going to retest tommorow via stool test.
5 weeks since stopped Bismuth and PPI
4 weeks since stopped Pylopass probiotic
2 weeks since stopped some essential oil
Is this enough to get accurate result?
Re: Stool test
Posted: Mon May 31, 2021 9:32 am
Sounds perfect. Good luck to your test tomorrow.
Re: Stool test
Posted: Tue Jun 01, 2021 1:05 am
by Clyde
Helico_expert wrote: Mon May 31, 2021 9:32 am
Thank You, the test came back negative today. I have 2 negative stool tests in the previous two weeks. But I still have some acidity problems, occasionally burning sensation.
Re: Stool test
Posted: Tue Jun 01, 2021 2:18 pm
That's great news!
It's normal to have some symptoms persist after H. pylori eradication. At least you know it wont get worse.
Now you can focus on the healing. Take PPI or H2 blocker if you think you need it.
