Any Clinical Labs Performing C14 UBTs Near Dallas, TX, USA?
mjfuter
Post by mjfuter »
Are any of you aware of any clinical labs performing the C14 urea breath test (UBT) near Dallas, TX, USA?
I checked with Quest Diagnostics, LabCorp and Clinical Pathology Labs and all 3 labs told me they only offer the C13 UBT which is supposedly less accurate.
Thanks!
Re: Any Clinical Labs Performing C14 UBTs Near Dallas, TX, USA?
I think they are equally accurate. but, depend on how you look at it.
lionwrist
Post by lionwrist »
I do tests that are a bit expensive. Does anyone have any suggestions?
dinosaur game
If you just want to know the presence or absence of H. pylori, C13/C14 breath test should be affordable.
