Antibiotic resistance testing
Posted: Thu May 30, 2019 12:50 am
by Adam
After how many treatments, should you consider antibiotic resistance testing? Are there any noninvasive methods to test for h pylori antibiotic resistance?
Re: Antibiotic resistance testing
Posted: Thu May 30, 2019 8:55 am
if you are in a low antibiotic resistance region, then I think after 2 treatment failure, you should do antibiotic sensitivity testing.
if you are in high antibiotic resistance region, then i think 1 treatment failure is sufficient to ask for antibiotic sensitivity testing.
Posted: Thu May 30, 2019 4:49 pm
by Adam
If a family member was infected and they went through multiple treatment failures before eradication, is it more likely you have resistant h. pylori? In this case, should you do antibiotic sensitivity testing even before first treatment?
Posted: Fri May 31, 2019 12:16 am
If personal hygiene is well maintain, especially brushing teeth, then transmission among family member is normally rare.
there are many cases where the one had H. pylori eradicated without problem, but the partner took many treatments.
In the end of the day, it's up to the patients. If you think you want such testing, your doctor should provide you.
