GI MAP
schism
Re: GI MAP
Post by schism »
The NP told me that even after 2 months of PPI, in my case, I won’t need to gradually stop it. I told her I had thought you needed to gradually stop and she said again nope not when you’re on it for that short of time.
Well I was on it for only 2 weeks. So I stopped taking it without stepping gradually down.
I did a google search for carbs and gerd and it seems there are tons of people whose gerd goes away when cutting down carbs as well. Mainly complex carbs.
schism
Re: GI MAP
Post by schism »
I’ve been having a rather embarrassing problem after the Pylera. My anus itches after BMs. Wasn’t happening during Pylera, only a couple days after and still today. I’ve been taking a probiotic. Will this itch go away?
Re: GI MAP
How long have you stopped Pylera and how long have this itch been on? Hopefully as your microbiome gradually comes back, the itch will go away. I have to say it is not something common.
schism
Re: GI MAP
Post by schism »
I stopped Pylera oct 9th and itch started about 4-5 days later and continues today. It only occurs after BM for about an hour. However I think the itch has gotten less severe.
If it is a yeast infection, is that something that can be treated with eating low-yeast/carb (already doing that) and probiotics or will I have to go get more medicine? It sounds like it may be treatable by getting good flora back?
Re: GI MAP
doesnt sound like a yeast infection to me. Since it's less severe now, i would wait another week or two and see how it progress. But if you are really concern, you should see a GP.
also, check out about worm. although it's less common among adults, it may be worth a look. You can buy anti-worm "chocolate" from chemist.
schism
Re: GI MAP
Post by schism »
It’s been 5 weeks since I’ve been off PPI and PYLERA. I just got the stool antigen test back and it is negative. :)
Re: GI MAP
wow! fantastic news! time for a big celebration!! :lol:
acb
Re: GI MAP
Post by acb »
Great! Congrats!
Re the itch. I have the same after 2 weeks of treatment. Did you find out what it is? Did it get better? It can be really painful.
schism
Re: GI MAP
Post by schism »
The itch is from Hemorrhoids. Im actually still nursing them too and are getting better. I had first bout of hemmoroids last year and for some reason they inflamed again after my treatment. May be conincedence.
LeslieAJ
Re: GI MAP
Post by LeslieAJ »
I also had a GI MAP done that showed positive hpylori, Virulence Factor dupA, and showed negative resistance to Clarithromycin. Level 3.5e2 vs normal of less than 1.03e3. I had treated it with natural treatments back over the summer and had had it 8 years earlier. This test interested me because I was left with healing ulcers I believe and food sensitivities. I was getting better but not there. I also recently realized I have a history of this on my mother's side of the family, a cousin and my grandmother. My brother currently having issues. My husband takes acid blockers 24-7 for a hiatal hernia and does not want to get tested because he does not want to go off acid blockers. So I am not sure if I had it and it was just low enough to not be detected, my husband re-infected me or if this test is accurate. My symptoms have slowly gotten worse so I believe I have it.
