GI MAP
schism
Re: GI MAP
Post by schism »
I got the biopsy results back. Two points of interest. H Pylori was positive. They want to go ahead and give me PYLERA as well as 20mg twice per day of omeprazole. The PYLERA is 10 day treatment.
I asked about eosinophilic esophagitis and they said I did have 30 per high-power field and the cut-off for eosinophilic esophagitis is 20, however the pathologist said she thinks that's just related to the inflammation from HP/reflux and not actually eosinophilic esophagitis.
What are your thoughts on that? The curious thing about my case is that I have only noticed reflux last summer and this summer, that is what lead me to believe it may be allergy-related and eosinophilic esophagitis.
Re: GI MAP
PYLERA is a good treatment. But many people experience side effects. So please try to finish it if you can.
I agree with your doctor about the esophagitis. Let's try eradicate H. pylori first. Hopefully that will fix your reflux problem. Then esophagitis can heal.
schism
Re: GI MAP
Post by schism »
Day 3 of PYLERA. Woke up this morning feeling pretty nauseous and had diarrhea. At what point do I need to be worried about the diarrhea? It’s not really watery, but is very loose. Concerned about C Diff...
After I crapped several times this morning, the nauseous let up and I feel quite a bit better. Is this "die off"?
Re: GI MAP
PYLERA has bismuth in it. Bismuth can prevent C. diff.
it's common that side effect kicks in around day 3. diarrhea (or loose stool) is common.
nausea is moderate severe, as there is risk of falling down. Vomiting can be serious too. Check with your doctor if you cannot tolerate the side effect anymore.
try to do something that you enjoy to avoid thinking about the side effect. Usually the more you think about it, the worse you will feel.
schism
Re: GI MAP
Post by schism »
I agree that thinking about it can make it worse for sure.
I did not end up puking, just felt like I almost wanted to. After I was done with the BMs, that sickish feeling stopped. I also am slightly dizzy feeling regularly. If I move around too quickly is when I noticed it the most. Just generally tired/sleepy as well.
My doctor wants me to be on a PPI for 2 months following the antibiotics -- but wouldn't that mean I cannot get the stool antigen test for at least 2weeks *after*? So I won't know if HP is eradicated until around 2.5-3months from now.
Re: GI MAP
talk to your doctor about gradually switch to H2 blocker during the first month. You can continue H2 blocker, eg Ranitidine, until the night before breath/stool test. most importantly is to have PPI completely stopped for at least 2 weeks before the breath test. After the test, you can switch back to PPI, if there is a need.
schism
Re: GI MAP
Post by schism »
What exactly causes the false-negative result on stool antigen tests or breath tests while on the PPI and not the H2 blocker? What is chemically happening with the PPI to cause a potential false-negative?
I am on the last day of PYLERA ; 2 more doses by end of day and I'm done. Overall it's been pretty good, but I've had these side effects:
- Generally very tired and headachy, very drained feeling.
- Early on it seemed like I had slight chills in the morning
- Bad taste in my mouth like all the time
- Sensitive eyes ; hard to look at computer screen for extended periods of time
- Soft stool, little bit of diarrhea. I took just one capsule of S. Boulardii a day after about the 3rd day of PYLERA and it seemed to help firm me up.
I'm hoping I bounce back quickly and these side effects disappear after I'm off the meds and get some good rest.
I've been on the PPI (40mg/day Omeprazole) for 10 days now. How would I transition to H2? Just start taking 20mg/day for maybe a couple days then just switch to an H2 blocker? Should it be even slower so like 20mg/day for a week, then like 10mg/day for a week, then finally switch?
I'd like to get stool antigen test ASAP to see if the PYLERA worked. I know I have to be away from PPI for 2wk prior, but what about antibiotics? I've read 4-6 weeks, is that true? So really I'llneed to wait until at least mid-november for the follow up stool test?
Re: GI MAP
For both tests, you'll need the bacterial load. PPI and antibiotics can reduce the H. pylori load and hence produce a false negative result for breath and stool test.
as a result, you'll need to stop PPI and antibiotics for at least 2 weeks. But the longer you wait the better. Some strains grow slower. If there are some left overs, the resistance, then when given enough time, they will grow up mass and can be detected by breath or stool test.
to transit into H2 blocker, you can slowly reduce the dose of PPI. such as 20mg/day or 40mg every alternate day. and replace the dose with H2 blocker.
schism
Re: GI MAP
Post by schism »
I decided to stop PPI instead of being on it for 2 months straight. After stopping, I did start getting reflux again right away. I was obviously hoping that if Pylera did kill the HP that I’d maybe be healed from the reflux, but I’m sure it takes time as well.
What’s interesting is I decided to go low carb for my diet and that has been as effective as the PPI was at stopping reflux incidents and reducing burping. It’s basically like I’m back on PPI now just because I cut carbs out. Any ideas as to why reflux would only occur after carbohydrate intake?
Re: GI MAP
interesting observation. It is usually believed that high protein diet increase acid level. But it seems like you have the opposite. Nevertheless, it's not good to stop PPI straight away. It is better to gradually stop it.
