Totally fed up!!
After first line treatment, various "second line" treatments can be used. The policy for H.pylori is: Make sure the infection is real (breath test for follow-up). Always give a high dose of PPI (acid blocker) when using amoxicillin. In the second treatment, give a different drug in place of clarithromycin.
fannytomy
Re: Totally fed up!!
Post by fannytomy »
It's not uncommon to still experience acid reflux symptoms even while on PPIs. Increasing the dose might help, but it's important to consult your doctor first. They may suggest further investigations like 24-h pH-impedance testing to determine if your symptoms are truly due to GERD or another issue. Also, consider lifestyle changes such as avoiding trigger foods and not lying down after eating to help manage symptoms.
Das Leben ist nur ein Spiel, aber ich werde es ernst nehmen und niemals davonlaufen
Return to “Ideas for Resistant H.pylori Infections”
