Multiple treatments
Re: Multiple treatments
There's nothing to heal because your stomach lining is intact and healthy. Mild chronic gastritis is just pathological finding when in fact nothing is wrong with your stomach during visual endoscopy. Your symptoms are not because of chronic mild gastritis for sure.
I agree.
All you can do is try out different probiotics or herbs. Hopefully, you'll find something that ease your symptoms.
Maybe an endoscopy every few years to monitor the recovery.
Lastly, mental stress can sometimes leads to unexpected gastritis.
there was an interesting experiment in the past, where the scientist continuously dip the mouse into water for hours everyday for months.
the batch of mouse eventually all developed severe gastritis.
AMERC
Post by AMERC »
I dont think I agree.
The doctor did see mild gastritis in endoscopy which was confirmed by the pathology.
Isn't gastritis an inflammation of the stomach lining? If this inflammation is not causing what else could be causing the symptoms..
The strange thing is I could go for days or couple of weeks with no symptoms but something I ate or was bit stress and I get flare ups which then lasts for days before calming.
Currently on pantoprazole 20mg a day in the morning
Surely there must be medication to heal stomach inflammation.
Loribert
Post by Loribert »
Hello
I just wanted to let you know that after my triple treatment for HP it took a very long time to heal . Many times I was convinced that I still had it and in fact went back and had repeat stool tests in fast succession and from different labs to double check accuracy. They were all negative. but I, like you, went through periods of feeling completely great and normal and then woke up feeling nauseous and awful again. This bug messes with your mind and I can only imagine the stress for you having discovered that you had it back again .
I had many symptoms, from heart palpitations to sore tongue and irregular stools, I also developed tinnitus in one ear and my tongue was coated white, which is the last symptom left now .
I changed my diet to Low FODMAP and stopped all meds . I made homemade live yoghurt and ate a small bowl every day. Then suddenly, one day I realised i hadn’t had symptoms for quite a while and the gaps between symptoms became longer and longer and eventually they went. I also consulted and did stool tests with a company called Health path, they are online, they are based in the Uk but do top quality stool analysis which is sent to a German lab . It gives you complete analysis of you stool sample including all markers for inflammation and bacteria report , in fact they were the people who first found my HP. They also tell you what you need to do to sort out issues with negative results.
I hope this all helps a little, and may go some way to help you on your journey with this dreadful bug .
AMERC
Post by AMERC »
Thanks. That's very helpful
When you say very long time to heal - how long was it ?
Do still get any symptoms ? What do you think night have made the difference ?
I suspect some degree of "autoimmune" disease. But this is yet to be proven.
Loribert
Post by Loribert »
Hello Again
Well I would say that the worst period was 3 months, post treatment, but then I probably had residual symptoms for at least 9 months post treatment. It was so very random and I could go for a week and feel nothing, then suddenly get awful nausea or burning tongue .
I am still left with tinnitus in one ear and a white coated tongue a year later !
For me, the worst symptom was the nausea, somehow I couldn’t ignore that as it just ruined my day and made me very anxious. I do also believe that anxiety is a strong component of HP, whether that is a true symptom or an associated effect is hard to know .
The Low FODMAP definitely helped alot , and I stayed on it for at least 3 months, then started introducing more variety, especially of vegetables . I do believe that getting your stomach microbiome healing as fast as possible is very important. Feed your stomach with plenty of vegetables, raw and cooked , encourage the good bacteria to proliferate with a whole, rich diet . If you can eat some live yoghurt, kefir or kimchi at least 3 times a week, even in small portions you will encourage the helpful bacteria to flourish and get some balance back in your stomach, which in turn reduces inflammation. Avoid sugar it promotes inflammation.
I am afraid for me there was no magic spell that transformed me after the triple therapy, but it did just slowly improve month by month, and maybe something that was tied into my microbiome finally healing too . But I would strongly recommend testing yourself regularly if you continue to experience symptoms……it’s a good way of eliminating any anxiety if the test keeps coming back negative, then you can just focus on healing your stomach naturally.
Hope this helps .
