Negative then positive
Maria.b
Re: Negative then positive
Post by Maria.b »
Hi could you please explain about my 7 yr old son he has never taken anti biotics infact he tested negative 1 1/2 yrs ago and now positive via blood test can his body fight and he get rid of this himself he has no symptoms but honestly some drs say treat him because i have intestinal metaplasia and some say dont but i cant live the rest of my life worried about this bacteria and i dont want him to suffer like i did. Also is helibacter only contagious when the person has symptoms pls help
blood test positive only means he was exposed to H. pylori before. It doesnt mean that he is currently infected with H. pylori.
the stool test is weak positive? it means weak accuracy.
is your son having any symptoms? most children carry H. pylori without any problem. Some scientists even believe that H. pylori is beneficial to children as it trains up the immune system.
if your children has no symptom, dont worry about it. H. pylori is a very chronic infection. It could take decades to get worse.
in your case, your son is most likely negative. can get another breath or stool test next month.
Maria.b
Post by Maria.b »
Hi sorry i dont under stand what u mean blood test shows he was exposed before. To h pylori my son has never had treatment for h pylori and when i was diagnosed my kids actually tested negative by stool my daughter tested negative by blood test last week so im so worried now he has no symptoms but he could easily give it to me my daughter ect and you wrote doesnt mean hes infected now how would this be possible when the blood shows positive thanku for all your help u really are a great help to all suffering xxx
cyprian zimunya
Post by cyprian zimunya »
What causes gastritis other than h pylori , anti inflammatory drugs and spicey food
Here is one situation how your son may be exposed to H. pylori.
when you (or anyone that carry H. pylori) feed your son, the saliva may contaminate the food. And your son's immune system sees H. pylori, kill it off before H. pylori can colonise (or live) in the stomach.
As long as everyone under the same roof brushes teeth. Then the chance of H. pylori present in the mouth is very low. H. pylori doesnt normally live in the mouth. the mouth is not the natural habitat. H. pylori cannot survive in the mouth. All H. pylori in the mouth is only temporary. A simple teeth brushing is sufficient to remove H. pylori.
elmaest
Post by elmaest »
Helico_expert wrote: Tue Aug 13, 2019 10:30 am regardless if you had H. pylori before, it is important to find out if you still carry H. pylori, especially after antibiotic treatment.
So, a follow up test is important. A breath test is probably better than stool test in your case. However, if breath test is not available, then you'll have to rely on stool test. Try to get a number from the stool test. not just a positive or negative. The strength of the positive or negative would give you a hint on how accurate the test is.
Yes, it is common that the symptoms may persist even after H. pylori eradication. However, the symptoms are weaker and will gradually get better.
Yes, anxiety will make it worse. Anxiety can trigger all gastric symptoms like H. pylori.
Usually after H. pylori eradication, the appetite will return and patient will gain weight. However, anxiety also plays an important role in appetite.
There are people having the symptoms but without H. pylori. These patients can only control the symptoms by taking PPI or H2 blocker.
If you did not eradicate H. pylori, your symptoms will likely to get worse. So it is best to have it eradicated.
Thank you for replying, i made a check up stool test today after 1 month of finishing triple therapy, came back negative.
I dont know either to be happy or not :(
I am feeing improvements but still not 100%
I am having my appetite back slightly better than before
Feeing a but nauseous in mornings but overall better but not best
What should i do?
improvement could be slow. How's your BMI? if your BMI is too low, you could experience weakness.
elmaest
Post by elmaest »
Checked my BMI, in the normal range.
Im having a bit of jaundice sometimes, is that related to h pylori?
What other check tests should i make?
Im really tired of these symptoms it has almost been 4 months.
tiredness could also due to lack of iron and/or B12. which these two are related to H. pylori.
I dont think jaundice is related to H. pylori. Nevertheless, do check with your doctor about your concern.
